machinarium
- 12
Please help me quick everyone, thank you in advance.
http://imgkk.com/i/EasJ1d.jpg
a/We have two photogates placed as in the figure. We drop a marble through these at a negligble distance above the upper gate. The upper starts a timer as the ball passes through its beam and the second stop the timer.
Prove that the experimental magnitude of freefall acceleration is given by
[tex]g_{exp}=2\Delta{y}/{(\Delta{t}})^2[/tex]
b/ For the setup and assume that gexp =9.81m/s2, what value of [tex]\Delta{t}[/tex] would you expect to measure.
c/This time, the upper photogate is placed 0.50cm lower than the first time. But we still drop the marble from the same height as the first time.
What value of gexp at this time will you determine?
Based on the problem, I think that [tex]\delta{t}[/tex] is the time when the marble passes through between two gates. But if it were, I couldn't get [tex]g_{exp}=2\Delta{y}/{(\Delta{t}})^2[/tex].
If it were not, I could do like that
We have [tex]{g_{\exp }} = \frac{{\Delta v}}{{\Delta t}}[/tex]
Because v0=0,
Hence,
[tex]a = \frac{{\Delta v}}{{\Delta t}} = \frac{{{v_2} - {v_1}}}{{{t_2} - {t_1}}}[/tex]The Attempt at a Solution
Because v0=0,
Hence,
