Motion Problem Constant Acceleration from 10 to 50 m/s in 2 secs
  • Thread starter Thread starter Shahab Mirza
    Motion
A car accelerates from 10 m/s to 50 m/s over a distance of 60 m, taking 2 seconds. The average velocity is calculated as (10 + 50) / 2 = 30 m/s, leading to the time calculation T = S/V = 60/30 = 2 seconds. While the use of S = vt is valid here, it is noted that this equation typically applies when initial velocity is zero. The discussion emphasizes the importance of using the correct equations of motion for constant acceleration. Overall, the solution is confirmed as correct, and the method is validated.
Shahab Mirza
A car traveling with constant acceleration increases its speed from 10 m/s to 50 m/s over a distance of 60 m . how long does this take?
a. 2 seconds b. 4 seconds .
Data :
Avg Velocity = 10 + 50 / 2 = 30m/s
Distance = 60 meter
time = ?
Solution :
S= V x T
making "T" subject . Then
T= S/V
T= 60/30
T = 2 seconds . This Answer is correct , but please tell me that the way I have solved this is correct or not? Thanks
Your solution is fine.
I agree with Doc Al. Your method is correct.
But I'm in a nit picky mood this morning. Use parenthesis in the expression for calculating the average velocity in order to show that the 10 and 50 are added together first before dividing by 2:
( 10 + 50 ) / 2.
Anyway, good work!
Thanks , But I am not satisfied with my solution, u know why sir? because S = vt is possible when initial velocity is 0 means herz equation s = vit + 1/2 a t^2 , but this eq can only be reduced to s =vt when acceleration is unity and initial velocity is 0 , in my case it isn't ? please make me clear or I am going fine?
Check this:
We have three equations of motion for constant acceleration along 1D,
1. v=u+at,
2. v*v - u*u=2as, and
3. S=ut + 1/2at*t
okay
Here u(initial velocity)=10m/s, v(final velocity)=50m/s, a=constant (so apply equations as it is a 1D problem), s=60, t=?
Using eq. 2 we get
2500-100=2*a*60
a=20m/s*s
Now using this value of 'a' in eq 1 we get;
50=10+20*t
t=2s
Thats it fella...
Physics Newbie said:
Check this:
1. v=u+at,
3. S=ut + 1/2at*t
okay
Using eq. 2 we get
2500-100=2*a*60
a=20m/s*s
50=10+20*t
t=2s
Thats it fella...
Yes Thanks , this was really a perfect solution , I was wondering how s = vt going to solve this , Thanks alot
What you're using, whether you realize it or not, is ##\Delta S = v_{ave}t##. Which is fine here.
Thanks , but the sir who replied above gave this solution.
Using eq. 2 we get
2500-100=2*a*60
a=20m/s*s
50=10+20*t
t=2sI think it was simple nasic problem, I followed question wrong i think.
Top tip:Whenever there is constant acc in 1D go for the equations...
Likes Shahab Mirza
Its very kind of you , Thanks for sharing knowledge , actually I am going to give medical college admission test this year , it has 3 subjects on which test will be based , 1 BIology . 2 Physics 3 Chemistry . so these little concepts will help me a lot , Thanks
Using eq. 2 we get
2500-100=2*a*60
a=20m/s*s
50=10+20*t
t=2s
There's nothing wrong with this solution, of course. But note the extra steps involved.
Your original approach using average velocity was just fine.
Likes Shahab Mirza
Doc Al said:
There's nothing wrong with this solution, of course. But note the extra steps involved.Your original approach using average velocity was just fine.
Yes I understood Sir , Thanks , I will keep all these things in my knowledge . Thanks
