Moving charge in gravitational field.
Sagar_C
An accelerated charge particle radiates. So, in the light of principle of equivalence, does a charge particle also radiate when it is in a gravitational field? Sorry if the question doesn't make any sense.
I would say no, because "acceleration" really means "proper acceleration". A box with a rocket on the bottom is the same as a box on the Earth because they both exhibit non-zero proper acceleration. If the box and the person inside are both being acted on by a graviational field and in free-fall, you can't tell that you're accelerating.
If the particle is following a geodesic, I don't believe it will radiate.
we've had some good long threads about this, search the archive here at PF to read through them.
I thought so but somehow couldn't find. :(...Would you have some time to lead to those?
Edited to add: I found one: https://www.physicsforums.com/showthread.php?t=65767 . Any other would be appreciated.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
