MPPT systems + Solar Panels major doubts
In summary, the solar panels generate power only when the shunt regulator dissipates the excess power. The excess power must be dissipated in order to keep the solar panels from overloading and damaging them. The professor's guiding us believe that the solar panels only generate what is required, but Mike believes otherwise. He suggests contacting a reliability engineer for more information.
roTTer
I'm working in the Power Systems team of CubeSAT. It is concerned with building a small student satellite with dimensions of 10x10cm.
Our basic block diagram is as follows
Solar panels-> In parallel Shunt Regulator -> Buck Converter->PRU (MAX8934A)->DC-DC Converters->Loads
The shunt regulator used is a Power MOSFET that is turned ON only when the operating voltage of the panels increases above 14V.
The major doubts I have are listed as follows:
1. Excess power dissipation : If at a particular time my system power requirements are lower than what the solar panels are able to generate in that particular condition then will the panels automatically generate lower power or is it necessary for the shunt regulators to dissipate the excess power?
The professors guiding us on this project are mainly from CS Engg. and believe that the solar panels only generate what is required. I believe otherwise. Am I wrong?
They may be true in Solar Panels connected in Direct Energy Transfer connection but how about when connected with a Buck Converter in series? The operating point then should depend on the input impedance offered by the converter(hence the operating voltage) and hence power developed will vary.
So don't we need a current and voltage monitoring system and with continuous monitoring dissipate the extra energy by using the Power MOSFETs that are connected in the shunt?
2. Maximum Peak Power Tracking - In this system with changing duty cycle, the impedance as offered by the converter defines the operating voltage of the panels. What I don't understand is how do we control the duty cycle of the converters that are available in the market?
Most of the energy that falls on your solar panels will turn to heat by nature of their inefficiency. That current that you do not consume represents charge carriers that will recombine and turn into heat in the panels. Typically, your efficiency wasn't that great to begin with, so the change is marginal.
I'd think carefully about the type of chips I used. Reliability is something to worry about, so I'd stick with a company that owns their own fab, and can offer military plastic packaging. MP offers a great improvement over consumer grade parts without the expense of X grade parts.
As for maximum power tracking, there's three alternatives I see off hand:
1. Ignore it, suffer the decrease in power, but at the improvement in reliability / complexity
2. Design a power tracker that alternately varies the load seen by the cells and trends towards the best load condition.
3. Utilize a temperature measurement to ascertain the best operating point of the panels.
As for controlling the process, you need to worry about the voltage seen at the panel and the current from the converter. For case number two, the PWM is varied such that the output current is maximized. For case number three, the converter's PWM is based upon the panel's output voltage versus the target output voltage for that temperature.
In any of these cases, your looking at more complexity than an off-the-shelf chip that was meant for cell phones or computer accessories; this is the sort of problem that is normally handled by a specialist. I'd suggest contacting a field service engineer at Linear Tech. They live for problems like this. Be respectful that his time is valuable, and he'll likely steer you to a solution.
Also, it won't hurt to get input from an experienced reliability engineer. They can help with semiconductor choices, stresses, and material choices for your substrate. Coefficient of thermal expansion, heat transfer, and survival of shock / vibration are very important.
Best of luck, wish I could be there, this sounds like a lot of fun :)
- MIke
Rotter,
With limted knowledge i am trying to answer your query,
1. Are you not using a battery for any reason? If you use a battery then the power generated is charged to battery, the battery discharges on load demand.
2. There are several algortihms available to calculate the voltage point where the maximum power occurs. based on that the algorithms will either increase the duty cycle or decrease it and then again reads the value of operating volatge, current and power of the panel to check if the maximum power is been obtained and again proceeds altering the dutycycle.
The increase or decrease in dutycycle is just an value(time), If it is minimum then it will not oscillate around the maximum powerpoint, but it experiments higher number of times increasing or decreasing. so the dutycylcle can be optimised after expermenation or simulation.
Hope this helps.All the best.
Related to MPPT systems + Solar Panels major doubts
1. How does an MPPT system work with solar panels?
An MPPT (Maximum Power Point Tracking) system is a type of electronic controller that optimizes the output of a solar panel by constantly adjusting the voltage and current to find the maximum power point. This allows the solar panel to operate at its peak efficiency, resulting in more energy being produced.
2. Do all solar panels require an MPPT system?
No, not all solar panels require an MPPT system. MPPT systems are typically used with solar panels that have a higher voltage output, such as those used in grid-tied or off-grid systems. However, some smaller solar panels may not benefit as much from an MPPT system and can operate efficiently without one.
3. Can I use an MPPT system with any type of solar panel?
Yes, MPPT systems can be used with most types of solar panels, including monocrystalline, polycrystalline, and thin-film panels. However, it is important to make sure that the MPPT system is compatible with the specific type and size of solar panel you are using.
4. How do I choose the right MPPT system for my solar panel setup?
The best way to choose the right MPPT system for your solar panel setup is to consult with a professional or do thorough research on the specifications of your solar panels. The MPPT system should be able to handle the maximum voltage and current of your solar panels, and it is also important to consider the size and capacity of the system for your specific energy needs.
5. How does an MPPT system improve the efficiency of solar panels?
An MPPT system improves the efficiency of solar panels by constantly tracking and adjusting the voltage and current to find the maximum power point. This ensures that the solar panel is operating at its peak efficiency, even in varying weather conditions, resulting in more energy being produced and a higher overall efficiency for the system.
  • Electrical Engineering
13K
10K
