MSc particle physics revision question - angle of muon from pion decay
The discussion revolves around a particle physics problem involving the decay of a pion into a muon and a neutrino, specifically calculating the angle of the muon when the neutrino emerges at 90° to the pion's direction. The key equations include energy and momentum conservation principles, leading to the relationship for the angle of the muon given by tanθ = (1 - mμ² / mπ²) / (2βγ²). Participants suggest using four-vectors for a more straightforward approach to the problem, emphasizing the importance of rearranging equations to utilize the properties of perpendicular vectors. The conversation highlights the complexity of the calculations and the need for clarity in applying conservation laws effectively.
BJD
I am trying to revise for PhD, going over MSc work. Could anyone help me with this question?
A pion traveling at speed β(=v/c) decays into a muon and a neutrino, π→μ + \nu. If the neutrino emerges at 90° to the original pion direction at what angle does the muon come off?
[ Answer: tanθ = ( 1 - m_{\mu}^{2} / m_{\pi}^{2} ) / ( 2βγ^{2} ) ]
→ using particle physics (pp) units:
E_{\pi} = E_{\mu} + E_{\nu} → energy conservation.
\bar{p_{\pi}} = \bar{p_{\mu}} + \bar{p_{\nu}} → momentum conservation. (3 vector)
βγm_{\pi} = |\bar{p_{\pi}}| (speed of light c not included as pp units)
invariant mass squared from decay of the moving pion: m_{\pi}^{2} = ( E_{\mu} + E_{\nu} )^{2} - ( \bar{p_{\mu}} + \bar{p_{\nu}} )^{2}
→m_{\pi}^{2} = E_{\mu}^{2} + E_{\nu}^{2} + 2E_{\mu}E_{\nu} - { \bar{p_{\mu}}^{2} + \bar{p_{\nu}}^{2} + 2\bar{p_{\mu}}\cdot\bar{p_{\nu}}}
substituting ( m^{2} = E^{2} - p^{2} ) into:
→m_{\pi}^{2} = E_{\mu}^{2} - p_{\mu}^{2} + E_{\nu}^{2} - p_{\nu}^{2} + 2E_{\mu}E_{\nu} - 2|\bar{p_{\mu}}||\bar{p_{\nu}}|cos ( 90°+θ )
gives:
→m_{\pi}^{2} = m_{\mu}^{2} + ( m_{\nu}^{2} = 0 ) + 2E_{\mu}E_{\nu} - 2|\bar{p_{\mu}}||\bar{p_{\nu}}|( - sin (θ) ) (the mass of the neutrino is taken as zero here)
also as: cos (90+θ) = cos(90) cos(θ) - sin(90)sin(θ) = - sin (θ)
I got stuck a few lines after this, can anyone who understands this help? Am I on the right track with the methodology?
You'll find it more convenient to work with four-vectors. Let ##p_\pi^\alpha = (E_\pi, \vec{p}_\pi)##, ##p_\mu^\alpha = (E_\mu, \vec{p}_\mu)##, and ##p_\nu^\alpha = (E_\nu, \vec{p}_\nu)## be the four-momentum of the pion, muon, and antineutrino respectively, where ##\vec{p}## denotes three-momentum. Conservation of energy and momentum gives you
$$p_\pi^\alpha = p_\mu^\alpha + p_\nu^\alpha.$$ Squaring this yields
$$m_\pi^2 = m_\mu^2 + m_\nu^2 + 2p_\mu^\alpha {p_\nu}_\alpha = m_\mu^2 + m_\nu^2 + 2(E_\mu E_\nu - \vec{p}_\mu \cdot \vec{p}_\nu),$$ which is the same thing you got with a bit more algebra.
Often, the trick to these problems is to rearrange the original equation so that the product of the various four-vectors results in the conveniently placed zero. For example, you know that ##\vec{p}_\pi## and ##\vec{p}_\nu## are perpendicular to each other, so their dot product will vanish. This suggests you try squaring ##p_\pi^\alpha - p_\nu^\alpha = p_\mu^\alpha##.
Thank you vela
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
