Multiple Integrals Homework: Mass of Gold in Ore
kd001
A hemispherical piece of ore of radius a contains flakes of gold. The flat base
of the ore is in the x, y plane and its curved surface is in the region z > 0,
where x, y, z are cartesian co-ordinates with origin at the centre of the base.
The gold density is kz kg m−3, where k is a constant. What is the total mass
of gold in the ore?
Using multiple integrals I got an answer of (pika4)/4 kg.
Can someone please check if this is the correct answer.
Thanks a lot. A simple yes or no will do.
Looks good to me!:smile:
Thanks!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
