Multivariable Calculus - a question of limits
PhysicalProof
Prove the following, using the meaning of a limit:
epsilon > 0, delta > 0
0 < sqrt(x^2 + y^2) < delta
| f(x) - 0 | < epsilon (1)
So, I know that I have to elaborate on the inequality in (1), further. However, I'm not sure of how to go about this. If I start transposing it seems to get much too messy and I end up with a proposed delta which seems far too complex. Is there some simplification that I'm overlooking here?
Any help is really appreciated, ta.
Could you not use polar coordinates instead?
Then the equation would be much simpler and the limit is just as r goes to 0
I did consider that but I'm pretty sure the limit definition must be used here (as a requirement).
Does anyone have any ideas of how to simplify this beast?
EDIT: Really need this one clarified guys. Does anyone have any hints at all? Even a vague idea.
Hint: use the fact that |x|<r and |y|<r, where r=sqrt(x^2+y^2).
Bingo, great hint, thank you! Subtle yet it serves me well :D♦
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
