Multivariable Minimization Question
SigurRos
I got this question as a take home exam question, and I can't figure it out for the life of me:
The temperature T(x,y,z) throughout a region in space is given by:
T(x,y,z) = 3*x^2*y*2+z^2
An insect is confined to move on the surface S : x^2 + y^2 = z. The insect is at the point P(1,1,2) on S and wishes to move in the direction in which T decreases the fastest. However, the insect can only move in directions tangential to S.
In which direction should the insect move from P(1,1,2)?
Here's what I've got so far:
The Temperature will decrease the fastest in the direction opposite to the Gradient of T(x,y,z), which is:
-<6*x*y^2 x, 6*x^2*y y, 2*z z> , which at (1,1,2) is equal to <-6 x, -6 y, -4 z>.
The equation for the tangent plane at (1,1,2) is:
PLANE: 2*(x-1)+2*(y-1)-(z-2) = 0
My professor says that Lagrange Multipliers may be used, but I'm not quite sure how. I'm not sure if the constraints are the plane, the surface S, or both. I tried computing using both the plane and S as constraints, but it didnt work because they only touch at (1,1,2). Any suggestions?
This is due in exactly 12 hours from right now, any help will be greatly appreciated.
Good news:
I got the solution.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
