Muon Tomography Evidence for Special Relativity?
In summary, Muon Tomography provides evidence for Special Relativity, but there is no need to refer to SR when interpreting the data.
racerunner
Muons are a popular way to provide evidence for Special Relativity. But, does Muon Tomography provide evidence for SR? Can you calibrate your muon detectors without reference to SR? Is there any need to refer to SR when interpreting the data?
I tutored a high school student who argued the affirmative (does provide evidence) in his research assignment – referencing articles about muon tomography and pyramids. I argued no – I said you don’t need to know about SR to watch a CRT TV. He argued yes and got 100% for his assignment. Where have I gone wrong?
Practically, yes. Only because of SR time dilation, a significant number of cosmic ray muons can reach the surface of the earth.
Wikipedia said:
The emergence of the muons is caused by the collision of cosmic rays with the upper atmosphere, after which the muons reach Earth. The probability that muons can reach the Earth depends on their half-life, which itself is modified by the relativistic corrections of two quantities: a) the mean lifetime of muons and b) the length between the upper and lower atmosphere (at Earth's surface). This allows for a direct application of length contraction upon the atmosphere at rest in inertial frame S, and time dilation upon the muons at rest in S′.[1][2]
Source:
https://en.wikipedia.org/wiki/Experimental_testing_of_time_dilation
Wikipedia said:
Muon tomography or muography is a technique that uses cosmic ray muons to generate three-dimensional images of volumes using information contained in the Coulomb scattering of the muons.
Source:
https://en.wikipedia.org/wiki/Muon_tomography
Likes vanhees71
What's your point? Why is it not evidence?
Likes vanhees71
I'd say the existence of usable numbers of cosmic ray muons at ground level is a test of SR, the same as anything that uses cosmic ray muons at ground level. Not sure that the tomography aspect adds anything, though, not from an SR test perspective.
Likes vanhees71
I'm not sure either. That's my question.
Muons arrive at sea level with an average flux of about 1 muon per square centimeter per minute.
Source:
https://cosmic.lbl.gov/SKliewer/Cosmic_Rays/Muons.htm
In the current paper, however, we measured a flux of about 1 muon per minute per square-cm at Galveston Bay and a flux of about 100 muons per minute per square-cm at Mt. Hamilton (4200 ft).
Source:
https://arxiv.org/abs/1203.0101
Calculated without SR-time-dilation, only about 0.3 out of a million muons reach the surface of the earth.
Calculated with SR-time-dilation and assuming ##\gamma = 5##, about 49,000 out of a million muons reach the surface of the earth.
Source:
http://hyperphysics.phy-astr.gsu.edu/hbase/Relativ/muon.html
Therefore, without SR time-dilation, the flux at sea-level would be (neglecting interaction with air-molecules)
##\frac{0.3}{49000} \frac{1}{cm^2min} \approx 6 \cdot 10^{-6} \frac{1}{cm^2min}##.
I am very aware of the use of SR to explain the prevalence of muons at sea level.
Given that there's a significant quantity of muons at sea level, does the process of detecting muons that have traveled through (pyramid)rock and comparing them to muons that have not traveled through (pyramid)rock have to take account of relativistic effects?
Actually, thinking about it, yes. The amount of scattering will depend on muon energy and momentum, and obviously these are relativistic muons. So you're testing your model of particle interactions at relativistic speeds, including your model of relativistic energy and momentum, over and above the mere existence of muons in large numbers.
Um...not exactly.
The experiment was done in the 1960's, after which this sort of evidence was no longer needed and was certainly not the best evidence. It was popularized because films were made available to zillions of high schools and colleges.
What was actually done was measure the muon flux as a function of height, fit a lifetime to it, and infer that muons are typically time-dilated by a factor of 8 or 9.
The way the story is often presented is to say "2-8 (or e-9 or whatever) is a fraction of a percent, so the fact that we see muons at all is proof of relativity". This is a little strong, since we don't really know how many we started with. If we started out with a few hundred times as many, we would see the right number on the surface,.
While that's true, it's also true that if there were that many muons at altitude, air travel would be vastly more dangerous. Pilots and flight attendants would be dropping like flies from radiation exposure.[/sup][/sup]
Likes dextercioby and Ibix
Yes. They measure the muon fluxes, coming in under different angles.
Atmospheric muons as an imaging tool
The angular distribution of the atmospheric muon intensity5 is found to be approximately proportional to ##cos^n\Theta##, where θ is the zenith angle and n ≈ 2 [25], with mild dependence of n on energy, latitude, altitude and depth [26]. This strong dependence on the zenith angle implies a large difference in muon rate, and therefore much longer exposure times are needed when observing an object from a horizontal or quasi-horizontal line of sight (which is typically the case when imaging mountains and volcanoes from a distance) with respect to a vertical one.
Source:
https://www.sciencedirect.com/science/article/pii/S2405428320300010
The same is done in school SR-experiments to avoid, that a second experiment must be carried-out on top of a mountain.
Special relativity in the school laboratory: a simple apparatus for cosmic-ray muon detection
This is accomplished by measuring the flux of muons, I(θ), arriving at different angles, θ, to the vertical, having followed different path lengths through the atmosphere.
Source:
https://iopscience.iop.org/article/10.1088/0031-9120/50/3/317
Likes dextercioby
Ibix: Thank you for hearing my question. Your answer is helpful to me. I would love to know if it's possible to shoot slow speed muons through rock as a comparison with atmospheric muons.
I still think that SR is not ESSENTIAL to making, calibrating and operating muon tomography. You could accidentally discover muons, measure their flux from all angles, calibrate flux loss through rock samples, and use that to probe the inside of pyramids without knowing what muons are. SR provides fruitful analysis and understanding but it is not essential to the task.
It worked for Rutherford. He fired alpha particles through gold foil at a time when "alpha" was a code word for "we don't actually know what this is".
Sort of.
In a non-SR world, these muons wouldn't exist. Sure you can posit another source of such muons, call it "sourcery" :wink: but once you go down that path you can quickly explain any experimental result whatever. "Yes, it looks like the water is boiling at 100C, but that's not what's really happening. It's magic instead..."
Likes Sagittarius A-Star and Ibix
To all above contributors: Thank you very much for taking the time to respond to my post.
Your argument seems to be that you don't need to understand the explanation for how something works to be able to use it to make, calibrate, and operate machinery that makes use of that something. History is full of examples of that sort of thing.
I would agree - the lodestone predates Maxwell by quite a few centuries, for example. However, it's still a test of magnetism (or SR, in the muon tomography case) even if you only understand that it works, not how it works. If one (pre-Maxwell) came up with a theory of lodestone dynamics that predicted like poles of two lodestones to attract, for example, one could immediately dismiss it on the grounds of existing known behaviour. Similarly, I would say the existence of muon tomography data is a test of any theory of muon creation and deflection, whether one has such a theory at hand or not.
FAQ: Muon Tomography Evidence for Special Relativity?
What is muon tomography evidence for special relativity?
Muon tomography evidence for special relativity is a scientific technique used to study the behavior of muons, which are subatomic particles that are created when cosmic rays interact with Earth's atmosphere. By measuring the decay rate of muons at different altitudes, scientists can gather evidence for the effects of special relativity, which predicts that time passes differently for objects moving at different speeds.
How does muon tomography provide evidence for special relativity?
Muon tomography works by detecting the number of muons that reach Earth's surface from the upper atmosphere. As muons travel at near-light speeds, they experience time dilation, meaning that they decay at a slower rate than if they were stationary. By comparing the number of muons detected at different altitudes, scientists can confirm the predictions of special relativity.
What are the implications of muon tomography evidence for special relativity?
The evidence gathered from muon tomography supports the theory of special relativity, which has significant implications for our understanding of the universe. It helps to explain phenomena such as time dilation and length contraction, and has been confirmed by numerous experiments and observations.
How does muon tomography differ from other experiments supporting special relativity?
While other experiments, such as the famous Michelson-Morley experiment, have provided evidence for special relativity, muon tomography offers a unique approach by using naturally occurring cosmic rays to study the behavior of muons. This allows for a more direct measurement of the effects of special relativity.
What are the potential applications of muon tomography evidence for special relativity?
The use of muon tomography for studying special relativity has practical applications in fields such as geology and archaeology. By measuring the density of materials underground, scientists can use muon tomography to create images of hidden structures, such as ancient ruins or mineral deposits. This technique has also been proposed for use in detecting nuclear materials in cargo containers.
