MWI and path of single electron
In summary, the MWI is a theory that says that the electron takes many paths through a double slit experiment and each path corresponds to a different world.
  • #36
PeterDonis said:
According to the MWI, the physical reality is the wave function; that's it. So whatever happens to the wave function is what happens in physical reality. In the double slit experiment, each time an electron goes through the experiment, the wave function ends up with one term for each possible position on the detector that the electron could end up at: each such term is just the piece of the electron wave function that ends up at that position, multiplied by the piece of the detector wave function that describes an electron being detected at that position. Each such term is multiplied by the amplitude for the electron to end up at that position.
But, as I said before, there is no way to show that physical reality actually works this way, because the MWI makes the same predictions as all the other interpretations, which have very different descriptions of what is happening in physical reality.
I've searched your previous statements. Let's tackle the issue head one. In the above you yourself stated that : "According to the MWI, the physical reality is the wave function; that's it." So you admit that the physical particle is the wave function. But elsewhere you stated that "No. Physical objects are physical objects. State vectors are mathematical objects that appear in mathematical models. They are not the same.". But in MWI, you admit they are the same? Please clarify.
Now to distinguish or test if MWI is correct. Then if we can change the wave function, and we can change the reality... then MWI is the right one. This is logically right and reasonable argument, right? Why not?
  • #37
That's not what you're doing. What you're doing is trying to give a precise interpretation to vague ordinary language. That doesn't work. Yes, the descriptions I've tried to give in different discussions, in ordinary language, might seem contradictory to you when put alongside each other. That's because they were different descriptions given in different contexts for different purposes, none of which were the purpose you're trying to put them to here. Trying to fit all those ordinary language descriptions, as they stand, into a single consistent picture is a fool's errand; there isn't one if the only tool you have to reason with is ordinary language.
If you really want to understand what the MWI, or any other interpretation of QM, says, you first have to learn the basic underlying math that all of the interpretations are based on. You have to learn the math of wave functions, state vectors, operators, Hamiltonians, Schrodinger picture vs. Heisenberg picture, etc., etc. (And if you really want to do it right, you then have to unlearn a good chunk of all that in order to learn quantum field theory, which you need to do in order to be relativistically correct.) Then you have to learn how all this math relates to what we actually observe in experiments, free of any interpretation. (Some physicists call what I am describing the "shut up and calculate" interpretation, but it's not really an "interpretation", it's just a description of the mathematical model and how it makes predictions and how those predictions are compared with experimental results.) If you don't understand all that, you won't even understand the questions that the various interpretations are trying to answer.
Actually learning all that stuff takes years, but if you want to take one small step, go back and read my post #12 in this thread. Notice that I don't use the words "physical reality" once. Nor do I make any of the claims that are apparently confusing you.
Then read my post #15 in this thread, and note carefully the statement of Manyme's that I quoted in that post and responded to. That's what I'm going to fall back on any time it looks like someone is misinterpreting my ordinary language attempts to explain claims that the various interpretations make.
Likes BvU
  • #38
PeroK said:
I never said philosophy was rubbish, just that it's not physics and isn't what we concern ourselves with on this forum.
Philosophy isn't rubbbish - its a perfectly legit disipine of much academic value.
The trouble with philosophy however is it never really resolves anything. Science has a resolving mechanism built right into its foundations:
That's the key difference. The reason we don't discuss it here is it leads to threads that go on and on but get nowhere. We actually want to help people understand science not be confused.
That said, since this is about MW there is a good textbook available on it by David Wallace who just happens to have a PhD is both philosophy and particle physics:
https://www.amazon.com/dp/0198707541/?tag=pfamazon01-20
Its not for the beginner though. But it does give the modern version of MW, which is basically the same as Consistent Histories, but it doesn't have the many worlds. In Consistent Histories QM is the stochastic theory about histories. In MW each history is a world.
Thanks
Bill
Likes PeterDonis and BvU
  • #39
  • #40
PeroK said:
But, also, is the state of the cat in terms of any macroscopic property really an observable in any QM sense?
Its a difficult issue, that, without going into the details (start a new thread if interested) is part of the Schrodenger Cat resolution, its very difficult to decide where the cat ends and environment begins. Feynman somewhere in the early chapters of his famous lectures looks at the issue from the viewpoint of what the surface of a table is. Look at deciding where it starts and ends is - well not even possible. Again this is part of the explanation of why things like tables etc have classical properties via decoherence.
Thanks
Bill
  • #41
Manyme said:
I understand it's the wave that interferes and how waves can result interference patterns, but I'm having a problem with it being just something mathematical and non-physical.
This is the diffference betweeen pure and applied math.
A good example to understand this is good old probability theory which is based on the Kolmogorov axioms. These axioms speak of events. Pure mathematics doesn't worry what events are. Applied math, as you gradually learn how to use it, builds up the concept of what an event is in practice.
The best book for doing that in QM I know is - Ballentine - QM - A Modern Development
https://www.amazon.com/dp/9814578584/?tag=pfamazon01-20
Contrast this with a pure math appproach:
https://www.amazon.com/dp/0387493859/?tag=pfamazon01-20
Glance through both and you will see the difference.
Thanks
Bill
  • #42
About quantum suicide or sorta..
Say your state is entangled with the system. If the electron is spin up.. you survive.. if the electron is spin down.. you commit suicide. After the experiment.. will you be alive or dead if it's MWI? It is emphasized the there is only one quantum system and there is only entanglement. I understand this and I know nothing gets duplicated in MWI. But is it not after the experiment.. one of you will come up dead and one alive? If nothing gets duplicated. Where did the alive version of you go and the dead version of you go?
  • #43
In the MWI this question is not well-defined; "you" do not have a definite state after the experiment. Your state is entangled with the state of the electron. It's no different from two electrons being entangled--neither electron by itself has a definite state, only the system consisting of both of them does. Here instead of one electron, there's you: so neither you nor the electron have a definite state, only the system consisting of both you and the electron does.
No.
There are no such "versions" of you in the MWI. So this question is also not well-defined.
Likes bhobba
  • #44
No.
But in the double slit experiment. The electron passes thru both slits in different branches/worlds. So they explain that we saw it hits one location in the screen in this world.. But in other worlds.. they hit different parts of the screen.. so how can you say the other worlds aren't there and actually duplicated? If someone else knows the answer to this. Please let us know because Peterdonis wil be back after 12 hours at this time and it is too long to wait for the answer. Thanks.
  • #45
No, it doesn't. The "branching" in the MWI--entanglement of a system with a measuring device--doesn't happen until a measurement is made. In the double slit experiment, that happens when the electron hits the detector screen and the position where it arrives is recorded. So according to the MWI, one run of the double slit experiment, with one electron, creates an entangled state with many terms (many more than two--how many depends on how accurately the detector screen detects position), each of which consists of the electron hitting the detector at a particular position and the detector showing a bright spot at that position.
The answer to this question is the same as all the previous times you asked it. What is going on is not a duplication of anything. It's just entanglement: the state of the system (electron in this case) gets entangled with the state of the measuring device (detector screen in this case). That's it. Do not ask this question again.
Likes bhobba
  • #46
Oh you are still awake.
But why do we only see one hit in the screen, what happens to the other hits.. do they just vanish. I can wait for the answer many hours later.
Meantime. Hope others can confirm if this is what orthodox Many World actually says in MWI.. because for many years.. I thought otherwise.
  • #47
According to the MWI, if we look at the screen, our state becomes entangled with the screen's state, just as the screen's state became entangled with the electron's state. So the state of the system as a whole--electron + screen + us--now includes multiple terms, each of which is a product of an eigenstate of electron position (corresponding to some location on the screen), an eigenstate of screen measurement of position (corresponding to the screen showing a spot at some location), and an eigenstate of us observing the screen (corresponding to us seeing the spot at some location on the screen). So now we, like the electron and the screen, no longer have a definite state: only the total system does.
This is how the MWI deals with any kind of interaction, so no matter what experiment or scenario you ask about, the answer will look the same.
Likes Vanadium 50, bhobba and mieral
  • #48
Thanks. For me I had hard time believing in Many worlds before because I thought the excess baggage was multiplicities of worlds where at the end of the day.. I have many me in other worlds and I can't believe this. But with the context of what you describe. Then I think Many world is really elegant and possible and I may just become a many worlder now. Thanks again for explaining something that removes many years of wrong thinking!
  • #49
Bear in mind that, when we talk about conscious observers like ourselves, the MWI is making an assumption (IMO a very big one): that each term in the entangled state I described has a separate consciousness associated with it.
(Note that, at least as I understand it, Schrodinger's original motivation in constructing his cat thought experiment was to produce a reductio ad absurdum of this idea--he expected that people would recognize as obvious nonsense the claim that a sentient being like a cat could end up in an entangled state where one branch was "alive" and the other was "dead". But for the MWI to work, this has to actually be the case.)
Likes bhobba
  • #50
True
But he went further and claimed an actual superposition of alive and dead states which a little thought shows it utterly impossible.
Without going into why, but we know it's an observed fact here in the macro world (we do know why but its not really relevant here here) the cats constituent parts have definite position. The position of those parts of alive and dead cats are totally different eg alive cats breathe and their heart beats - dead cats do not. Since cats actually have definite position, like virtually all objects here in the macro world, you can't have a superposition of position - this is from the very foundations of QM. So you can't have a macro object like a live and a dead cat in superposition. Yes I know the great Dirac states in principle you can have a superposition of any two states - but what is, for theoretical convenience considered true, in principle (it's given a name BTW the strong superposition principle and is used a lot in the the foundations of QM) is not always true in practice for various reasons like the above.
Thus the issue is exactly as Peter said - one branch is alive - the other dead - an actual superposition is not possible.
Personally my view is MW is just the consistent histories interpretation where QM is the stochastic theory of histories with the twist each history happens in its own world. In that way we just have an evolving state for the whole universe - or maybe multiverse if some cosmological theories are correct. Which is better - it's purely a matter of taste.
Thanks
Bill
  • #51
Indeed. Its goes right to the foundations of the decision theory approach they use to derive the Born Rule. Its a not usually talked about way to view probability. But some areas of applied math use it like credibility theory used in actuarial science.
Thanks
Bill
  • #52
You just mentioned earlier that "There are no such "versions" of you in the MWI. So this question is also not well-defined.". And yet above you said MWI is making an assumption that each term in the entangled state I described has a separate consciousness associated with it.
You mean your MWI or PF MWI is different from the mainstream MWI? Who are the public authors who said that in MWI each term in the entangled state has a separate consciousness associated with it?
  • #53
No, it isn't. We don't observe the position of every atom in the cat. We observe the cat's position--which is to say, we measure an operator which is, at best, some kind of average position of all the atoms (center of mass position, perhaps), plus a very coarse set of relationships between parts of the cat (the head's at this end, the tail's at this end, the legs are sticking out this way, etc.) Going from that to the claim that all ##10^{25}## or so atoms in the cat have definite positions is a huge leap: the macroscopic state we observe is perfectly compatible with every atom in the cat being in a superposition of position states with a fair bit of spread, atomically speaking.
This is self-contradictory. "One branch is alive - the other dead" means that the state of the system as a whole--cat entangled with radioactive device that does or does not decay, and does or does not release poison--is in a superposition, of two terms (atom not decayed-cat alive, and atom decayed-cat dead), which describes an entangled state. The system as a whole does not have an alive cat or a dead cat in it; it has a cat entangled with a radioactive atom. This is an actual superposition--it's just not an actual superposition of "alive cat" and "dead cat". It's a different superposition, describing entanglement of the cat with the radioactive atom.
  • #54
That's because the MWI, at least in the form in which it purports to explain our everyday observations, in which we observe measurements to have definite single results, has to explain how that can be the case given the entangled state that comes out of a measurement. The explanation is that, when we write down such an entangled state, for example, this one:
\Psi_\text{final} = a \vert u \rangle \vert U \rangle \vert O_U \rangle + b \vert d \rangle \vert D \rangle \vert O_D \rangle
where ##u, d##, ##U, D##, and ##O_U, O_D## are, respectively, the eigenstates of the electron (up/down), the measuring device (measured up/measured down), and the observer (observed up result/observed down result), the observer states have to include conscious experience--so, for example, ##O_U## has to mean "the observer consciously experienced seeing the measuring device give an up result", and similarly for ##O_D## with down. So this entangled state describes an entanglement that includes two different conscious experiences in it, which are separate and cannot communicate at all with each other, but it's still one single state of the overall system. That's what the MWI has to claim, in order to explain our everyday experience of measurements. (And it's also where all the talk about "splitting of worlds" and so forth comes from.)
No.
Any author that says that the MWI can explain our everyday experience of measurements. See above.
Likes mieral
  • #55
But is it not most popular books describe the superposition as an actual superposition of alive cat and dead cat? My dozens of popular books about QM is tucked in wooden crates and it's difficult to look for the physical books.. But if anyone here has any popular books on QM.. please review if it says the superposition has actual alive cat and dead cat or it is as Peterdonis described that although it is an actual superpostion.. it's a a different superposition thing describing the entangement of the cat with the radioactive atom. Peterdonis explanation makes sense and more elegant but I need to actually see the popular QM books also state it like Peterdonis does. So others please verify this.
And Peterdonis. I need to know something. When you stare at the screen detectors in the double slit experiment. How long does the entanglement last? Is it like split milliseconds or say 0.00000001 seconds where the different terms in the superposition exist or does it last many seconds such that when I'm looking at the detector.. I can say "Oh, the other me is seeing the hits in other positions and I'm just part of the terms of this different superposition thing and when I close my eyes. All those me won't exist anymore and they are really not separate me but this different entanglement thing that Peterdonis is describing". Or does the entanglement occurs like in 0.0000001 second that I won't be able to even think or say the words?
  • #56
Popular books are not valid sources here on PF. You are illustrating one of the reasons why: they misstate the actual physics.
No, you don't. You need to learn QM from an actual textbook. Then you need to work out the math for yourself and understand what it is actually telling you.
According to the MWI, the entanglement never goes away, because once you've seen the detector showing a spot in a particular place, you remember seeing it that way, and everything else you observe is consistent with it being that way. So the entanglement has to involve everything that could possibly be affected by the location of the spot, your perception and memory of the location of the spot, etc.
We don't know how fast the entanglement actually occurs, because we don't observe it continuously in the process of occurring. We just run the experiment and see a spot in a particular place on the screen. It might not even be meaningful to assign a "length of time" in which the entanglement occurs--except that it must happen much faster than our conscious perceptions happen, which is pretty slow on the atomic scale (tens to hundreds of milliseconds).
  • #57
Leave them there. One good textbook is what you need.
The different terms never go away - that's what makes MWI what it is.
Likes bhobba
  • #58
You wrote above the entanglement never goes away or forever.
Yet above you wrote it it must happen much faster than our conscious perceptions or an instance in time.
I kept reading them again and again to see how you can describe two paragraphs in totally opposing views.. forever vs an instant in time. perhaps there are two you in different terms of the entanglement and each paragraph occurs in different branches? But you said there is only one you.. maybe our thoughts came from different us.
But let's take the first paragraph where you said the entanglement never goes away. What happens to the other awareness where you see other hits? This is the part I don't understand. I think some book said they evolve their own. meaning in another worlds or branches, there are other hits with separate history. Even Bill mentioned this.
I hope others can share how they understood the MWI.. what happens to the other hits if the entanglement never goes away? pls answer this specifically and let's focus on this aspect. Thanks!
  • #59
The entanglement is result of the interaction between the system we're measuring and the measuring device, so happens more or less quickly according to the details of that interaction. This is when the wave function is changing from ##\Psi_{initial}## to ##\Psi_{final}##. The entangled state ##\Psi_{Final}## then continues to evolve forward in time, more or less forever. So the transition from the pre-measurement state to the post-measurement state happens quickly, but the results of the measurement persist.
  • #60
It takes an instant of time (or at least a very short time) to go from "not entangled" to "entangled". Once that happens, "entangled" lasts forever. What's the problem?
  • #61
This should be obvious; just do the same thing for subsequent measurements as we did for the initial measurements.
For example, suppose we measure the spins of two electrons (call them electrons 1 and 2) in succession, both in the up/down direction. The total evolution looks like this (hopefully the notation is clear):
\Psi_0 = \left( a_1 \vert u_1 \rangle + b_1 \vert d_1 \rangle \right) \left( a_2 \vert u_2 \rangle + b_2 \vert d_2 \rangle \right) \vert R_1, R_2 \rangle \vert O_{R1}, O_{R2} \rangle
\rightarrow \Psi_1 = \left( a_2 \vert u_2 \rangle + b_2 \vert d_2 \rangle \right) \left( a_1 \vert u_1 \rangle \vert U_1, R_2 \rangle \vert O_{U1}, O_{R2} \rangle + b_1 \vert d_1 \rangle \vert D_1, R_2 \rangle \vert O_{D1}, O_{R2} \rangle \right)
\rightarrow \Psi_2 = a_1 a_2 \vert u_1 \rangle \vert u_2 \rangle \vert U_1, U_2 \rangle \vert O_{U1}, O_{U2} \rangle + a_1 b_2 \vert u_1 \rangle \vert d_2 \rangle \vert U_1, D_2 \rangle \vert O_{U1}, O_{D2} \rangle \\ + b_1 a_2 \vert d_1 \rangle \vert u_2 \rangle \vert D_1, U_2 \rangle \vert O_{D1}, O_{U2} \rangle + b_1 b_2 \vert d_1 \rangle \vert d_2 \rangle \vert D_1, D_2 \rangle \vert O_{D1}, O_{D2} \rangle
In other words, each time a measurement happens, it creates another entanglement. So after two measurements, we have an entangled state containing four terms, one corresponding to each possible combination of the results of the two measurements.
Likes bhobba
  • #62
You mentioned this critical passage: "So this entangled state describes an entanglement that includes two different conscious experiences in it, which are separate and cannot communicate at all with each other, but it's still one single state of the overall system".
There are two different conscious experiences within the single state of the overall system. Yet you don't want to say the persons are duplicated. So it's the same person can both feel sad and happy but the overall system is still one single state. Let's say if the hit of the double slit detector screen in the left half side.. you are sad, if the hit of the screen is in the right half side, you are happy. And the result is right half side detector hit, so you are happy. However, the other you is sad because it's left half side hit. Yet you don't believe you are duplicated. Maybe the rule is this. Potential/Hamiltonian can never be duplicated, yet it can experience different entanglement. So you as Peterdonis is never duplicated.. yet there is another side of you that is sad because of the left side hit that you didn't see (because you are seeing right side hit which made you happy). This is bewildering. Hope other Many Worlders can come and state if they agree with this. I can't imagine another side of me having other experiences in other branches yet I'm still one person and not duplicated. This seems contradictory. I'm still absorbing it though.. so don't worry.
Dear other Many Worlders, what do you think?
No.
  • #63
Because as far as the physics we know is concerned, the person--the quantum state--is not duplicated; it's just entangled. I'm personally not a proponent of the MWI, so I'm not saying I agree with the claim about conscious experience. I'm just saying that the claim about conscious experience is necessary to reconcile the MWI with our actual observations. We don't have a quantum theory of consciousness, so nobody has any way of knowing whether the claim about conscious experience is actually consistent with the quantum state being entangled. If it turns out it isn't, then something will have to give--either the MWI will be falsified, or something about the quantum state must be different from what we've been saying. (The second alternative, however, would require a wholesale change in all aspects of QM, because what we've been saying about the quantum state is a simple consequence of unitary evolution, which is one of the most fundamental aspects of QM as we understand it.)
  • #64
Let's uncomplicate it by treating an atom... the electrons in the atoms are entangled to the nucleus. So you are right the different engenvalues don't mean the atoms are duplicated many times. There is only one nucleus and one electronic cloud and the potential and Hamiltonian don't get duplicated. So entangled electrons are something unclassical because each component don't have a state and only the whole system has state and we can't imagine what it would be like to be entangled electrons. That's understandable.
But we complicate it when we used a camera to view the atoms. We can say the camera is entangled to the atoms such that the equivalent of say spin up and spin down would form different branches. But this shouldn't happen.. it's more logical you can't make the camera become entangled to the atoms eigenvalues. Why do we believe it is possible at all for the camera and atoms to get entangled? Therefore the correct interpretation is one where they shouldn't be able to get entangled in the first place.
Imagine entangled electrons looked like smeared ghosts. Since a camera and atoms can't be smeared ghost.. then no entanglement should be possible between camera and atoms. What interpretation disallowed such entanglement?
  • #65
This phrase "within the single system" doesn't seem quite right. I think it should be more like this:
There is single Hilbert space where two conscious experiences are two different directions in that Hilbert space. If state vector is not exactly in one of those two directions we can write the state vector as superposition of two conscious experiences. Then two conscious experiences get fractional probability amplitudes. So if we want to claim that both possibilities are realized then we have to give different interpretation for probability amplitudes squared. Some kind of interpretation that allows for both states to coexist with reduced weight.
  • #66
PeterDonis said:
No, it isn't. We don't observe the position of every atom in the cat..
Of course we don't - but, as you allude to, we can observe parts like the heart, blood, and lung and they have positional behavior entirely different in alive and dead cats. But point taken - its very hard to disentangle a cat from its environment (eg it must breathe air) and that is at the atomic level which we don't directly observe.
Hmmmm. I was thinking in terms of a mixed state ∑p1|a><a| + p2|d><d| where |a> is the alive state and |d> the dead state. The decoherence inherent in being a cat (ie its entangled with the environment) leads to the mixed state. It also leads to the rather 'interesting' issue of exactly what is the alive state and dead state because of that entanglement ie it can't be alive unless it breaths air. It reminds me of Feynmans discussion on the surface of a table in his lectures. The closer you examine it the less clear exactly what that surface is becomes. Or have I somehow goofed here?.
Thanks
Bill
  • #67
Nugatory said:
Leave them there. One good textbook is what you need. The different terms never go away - that's what makes MWI what it is.
For the OP, just as a simple example you have two systems that can be in state |a> and |b>. If system 1 is in state |a> and system 2 in |b> then that is written as |a>|b> and conversely we have |b>|a>. Now according to the principle of superposition you can have a superposition of these two states say 1/root(2) |a>|b> + 1/root(2)|b>|a>. The systems are called entangled. If you chug through the (the reference I give at the end does it) math you find something interesting - suppose we observe just system 1 then it behaves as if its in the following mixed state 1/2 |a><a| + 1/2 |b><b|. Mixed states are different to superposition's. One way to create a mixed state is to present states for observation with the probability of the number in front of the terms in the mixed state. In the forgoing that would mean the system 1 is in state |a> 1/2 the time and state |b> the other half. But that is not how this mixed state was created - it was created from entanglement. The thing is we can't tell the difference. The system taken as a whole is still in superposition - that never goes away - but the subsystems behave differently due to the entanglement. This is a very simple illustration of decoherence (its not true decoherence which involves entanglement with such a large number of things it can't be disentangled) but helps understand what's happening.
This thread is at the I level, THE reference at that level where all this is explained in detail is:
https://www.amazon.com/dp/3540357734/?tag=pfamazon01-20
Thanks
Bill
  • #68
I am not a MW'er but simply out of interest have studied it.
If you want to study the detail here in the book I studied:
Its very theorem, proof, theorem proof in style.
Its also very very elegant.
What do I think of what Peter says - from my study its pretty well spot on, although rather non intuitive.
Thanks
Bill
  • #69
Why not? In order for the camera to tell us anyting about the atom, it has to become entangled with the atom. That's how measurement works.
No, because on this interpretation, measurement would be impossible, and we could never have any information about anything.
No, don't "imagine" anything. Look at the actual math. Trying to "imagine" how things are in the quantum world, when you don't understand the math, is a fool's errand.
  • #70
Mixed states can't be produced by unitary evolution from pure states, and according to the MWI, the state of the entire system is always pure. So that's the viewpoint I have been taking in this thread. You are correct that experimentally we can't tell whether the state after a measurement is the pure superposition state I have been using here, or the mixed state you were thinking of. But the MWI says that the state is the pure one.
Likes bhobba
9K
10K
