NASA My rough idea on a near light drive
  • Thread starter Thread starter MoistOxi
    Drive Idea Light
The discussion centers on the misconception that moving a weight inside a trash can can induce movement in the can itself. It emphasizes the need for friction to initiate movement, which would result in the trash can moving in the opposite direction. The concept of conservation of momentum in an isolated system is highlighted as a critical principle that invalidates the idea of a reactionless drive. The thread concludes with a reminder that such mechanisms violate the laws of physics and are against forum guidelines. Ultimately, the discussion is locked due to the persistent misunderstanding of these fundamental scientific principles.
MoistOxi
TL;DR Summary
Lets just get straight into it. Think of a big trash can with a 10 kg weight inside, Now if you were too throw the weight at one side of the trash can it would move the can, now let's think of that in space. If you had a large cylinder with a rod in the middle. On that said rod is an object that can change its mass, that object can be slid across said rod too either side, doing the same think but in micro gravity making it accelerate constantly with each pound. Now I know this is not perfect.
Please add too this idea.
Sorry. No motion of a weight inside your trash can will induce exterior movement in the trash can/weight system.
Think about this: how will you get your 10kg weight moving in the first place? You'll need to create friction with the trash can to move the weight forward. That will push the trash can backwards.
Likes russ_watters
MoistOxi said:
Summary:: Let's just get straight into it. Think of a big trash can with a 10 kg weight inside, Now if you were too throw the weight at one side of the trash can it would move the can, now let's think of that in space. If you had a large cylinder with a rod in the middle. On that said rod is an object that can change its mass, that object can be slid across said rod too either side, doing the same think but in micro gravity making it accelerate constantly with each pound. Now I know this is not perfect.
Read up on the subject of Conservation of Momentum in an Isolated System and you will see where you are going wrong. It's a common misconception by folks who are new to science. :smile:
Likes russ_watters
The weight would move back and forth, it would accelerate and decelerate but the acceleration forward would yield a higher speed by a small amount many times creating a slow acceleration. (If this doesn't fix it, I accept my defeat as others are more scientifically erudite.)
No it doesn't fix it. Try doing the search I suggested, and here is the Wikipedia article to get you started:
https://en.wikipedia.org/wiki/Momentum#Conservation
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
