- #36
Spacie
- 38
Why there should be the consensus on how SR works? The important thing is that my way of looking at things does not contradict the theory, helps me to understand it better, does not lead to false paradoxes or "a wrong answer at first".harrylin said:Then you are aware that your idea does not fit with the consensus of how SR works.
Your assumption leads to a claim that is inconsistent, as different ways to solve the same problem lead to the contrary conclusion to what you state. However, that's a different topic on its own, to be discussed (and likely it already has) in a separate thread. And gwellsjr already sketched another, similar objection. In short, the way SR works doesn't match a space that is distorted by moving bodies. And I wrote a full paper in a mainstream physics journal on SR length contraction; you can read from me.
PS: You may also want to start the topic "Why is space not deformed by Lorentz contraction?".
Harald
What is the claim that is inconsistent, and inconsistent with what? And what is the contrary conclusion to what I state?
You seem more flexible on a neighboring thread:
harrylin said:The same thing can be "explained" in many ways, and it depends on your thinking which one you find most satisfying.
Some people like a more mathematical explanation (it's because of the invariance of c that lengths and times are measured differently at different speeds) or a more physical explanation (it's because speed affects the measurements of lengths and times in the right way that c is invariant). So what one person regards to be a consequence, another person will regard as cause - it's more of an interplay of phenomena that are consistent with each other.
Speed affects the measurements of lengths, you say. All the relevant lengths of all objects at once. It seems more logical and consistent to say that the space the objects are contained in is contracted, which affects all objects in it.
