MHB Name102's question at Yahoo Answers regarding displacement vs. distance
  • Thread starter Thread starter MarkFL
    Displacement
The discussion addresses a question about calculating displacement and total distance traveled by a particle with the velocity function v(t) = 2t - 8 over the interval 0 ≤ t ≤ 10. To find displacement, the area under the velocity graph is analyzed, resulting in a displacement of 20 meters. For total distance, the areas above and below the x-axis are combined, yielding a total distance of 52 meters. The calculations involve both geometric methods and calculus, demonstrating how to integrate the velocity function. The thread encourages further calculus inquiries from participants.
MarkFL
MHB
Here is the question:
The velocity function (in meters per second) for a particle moving along a line is v(t)=2t−8?
Over the time interval 0≤t≤10.
1)Find the displacement of the particle over the time interval.
2) Find the total distance traveled by the particle over the time interval.
Here is a link to the question:
The velocity function (in meters per second) for a particle moving along a line is v(t)=2t−8? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Name102,
First, let's look at a graphical method, involving simple geometry, which we can use to answer the questions. Let's graph the linear velocity function, and take the magnitude of the area between the $x$-axis and the velocity function as distance, and applying the sign for displacement.
The area below is shaded in red and the area above is shaded in green:
Now to find the displacement we subtract the red area from the green and for the distance we add the two areas. This is easy to find since they are both right triangles.
The red area is:
[math]A_R=\frac{1}{2}\cdot4\cdot8=16[/math]
The green area is:
[math]A_G=\frac{1}{2}\cdot6\cdot12=36[/math]
1.) The displacement of the particle is then [math]A_G-A_R=36-16=20[/math]
2.) The total distance traveled is then [math]A_G+A_R=36+16=52[/math]
However, only in cases of constant acceleration will it be this simple, so let's examine how we may do this by applying the calculus.
We may orient our coordinate axis such that the initial position of the particle coincides with the origin.
For displacement, we have the IVP:
[math]\frac{dx}{dt}=2t-8[/math] where [math]x(0)=0[/math]
Integrating with respect to $t$, we obtain:
[math]\int\,dx=\int 2t-8\,dt[/math]
[math]x(t)=t^2-8t+C[/math]
Using the initial values, we may determine the value of the parameter $C$:
[math]x(0)=0^2-8(0)+C=0\,\therefore\,C=0[/math]
and so the solution satisfying the IVP is:
[math]x(t)=t^2-8t[/math]
Now, the displacement is the final position minus the initial position:
[math]x(10)-x(0)=20-0=20[/math]
For total distance, we have the IVP:
[math]\frac{dx}{dt}=|2t-8|[/math] where [math]x(0)=0[/math]
Here, we may treat the function as piecewise and use two integrals:
[math]\int\,dx=\int_0^4 8-2t\,dt+\int_4^{10}2t-8\,dt[/math]
[math]x=\left[8t-t^2 \right]_0^4+\left[t^2-8t \right]_4^{10}=(16-0)+(20-(-16))=52[/math]
To Name102 and any other guests viewing this topic, I invite and encourage you to post other calculus questions here in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
