Undergrad Natural direction of pushforwards and pullbacks
  • Thread starter Thread starter ergospherical
    Direction Natural
Vectors can be naturally pushed forward through a diffeomorphism, while 1-forms and functions are typically pulled back, which relates to their dual nature. The pushforward of vectors aligns with the tangent of a curve in the original manifold, whereas the pullback of 1-forms corresponds to their evaluation on vectors. This duality is rooted in the definitions and properties of these mathematical objects, where vectors act on functions and 1-forms act on vectors. The discussion highlights that the existence of pushforwards and pullbacks can be understood through commutative diagrams and the relationship between Jacobi matrices. Overall, the distinction arises from the inherent definitions and roles of vectors and 1-forms in differential geometry.
ergospherical
Education Advisor
Insights Author
Given a diffeo ##\phi : M \rightarrow M'## (and with ##f## a function on ##M'##), vectors ##X## can be "naturally" pushed forward with ##\phi_*## from ##T_{p}M## to ##T_{\phi(p)}M'## subject to ##\phi_{*}X(f) \bigg{|}_{\phi(p)} = X(\phi^* f) \bigg{|}_{p}##. And 1-forms ##\omega## are naturally pulled back from ##T^*_{\phi(p)}M'## to ##T^*_p M## subject to ##\langle \phi^* \omega, X \rangle \bigg{|}_{p} = \langle \omega, \phi_* X \rangle \bigg{|}_{\phi(p)}##.
Making use of the inverse ##\phi^{-1}: M' \rightarrow M##, I think it's possible to also push forward 1-forms (##\omega \mapsto \phi_* \omega##) subject to e.g. ##\langle \phi_* \omega, X \rangle \bigg{|}_{\phi(p)} = \langle \omega, {(\phi^{-1})}_* X \rangle \bigg{|}_p##. And similarly I think we can also pull back vectors (##X \mapsto \phi^* X##) subject to e.g. ##\phi^* X(f') \bigg{|}_p = X({(\phi^{-1})}^* f') \bigg{|}_{\phi(p)}##, where ##f'## is a function on ##M## [are these right?].
In any case my question is why do vectors seem to naturally be pushed forward, whilst 1-forms and functions seem too be naturally pulled back... is it simply a matter of definition? Thanks
A tangent vector is naturally pushed forward since it is the tangent of a curve ##\gamma## in ##M## and ##\phi\circ\gamma## is then a curve in ##M’## whose tangent is the pushforward.
Likes cianfa72, ergospherical and vanhees71
Intuitively in the general case in which ##\phi : M \rightarrow M'## is not injective we cannot define a pullback of a vector field from ##M'## to ##M## the same way we cannot define a pushforward of a scalar field (function) from ##M## to ##M'##.
In the latter case which would be the value of the function at the point P in ##M'## having as inverse image through ##\phi^{-1}## different values of the scalar field (function) defined on multiple points in ##M## ?
I'd say for functions is quite clear, because it is just composing with the map. For dual objects it goes the opposite way. Since vectors evaluate on functions, they are pushed forward. One forms evaluate on vectors, so they are pulled back.
Likes ergospherical
If you have a bijection, then you are automatically disposing of all directions. But bijection in this case means diffeomorphism, which is quite a strong condition.
Pullbacks and pushforwards are dual operators and their existence can be described by commutative diagrams. For short: one is the Jacobi matrix, the other one is its transpose.
Pushforwards are easier to visualize because we can imagine a vector, but not so much a 1-form. It's
(\varphi_*(v))(f)=v(f \circ \varphi) \text{ versus } (\varphi^*\nu)(x) = \nu(\varphi(x))
Your question is a bit like: What if I start with a smooth function ##f^*\, : \,M^*\longrightarrow N^*## on the dual spaces? But don't demand to work this out. I would get lost in directions. However, it's a legitimate setup.
I tried to sort it out here:
https://www.physicsforums.com/insights/pantheon-derivatives-part-iii/
but it is more about definitions than about the why's.
Likes ergospherical and vanhees71
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 36 ·
