MHB Natural frequency of a pendulum being lowered at 2m/s
A heavy machine weighing 9810 N is lowered at a uniform velocity of 2 m/s until the winch is stopped, causing vibrations in the system. The mass of the machine is calculated to be approximately 1000 kg. Young's modulus for steel is utilized to determine the force on the cable, leading to the calculation of the elastic potential energy and the amplitude of the vibrations. The period of the oscillation is derived from the spring constant using the formula T = 2π√(m/k). The rough calculations yield a period of about 0.19 seconds and an amplitude of approximately 0.035 meters.
Dustinsfl
A heavy machine weighing \(9810\) N is being lowered vertically down by a winch at a uniform velocity of \(2\) m/s. The steel cable supporting the machine has a diameter of \(0.01\) m. The winch is suddenly stopped when the steel cable's length is \(20\) m. Find the period and amplitude of the ensuing vibration of the machine.
From the question, we know that \(m\ddot{x} = 9810\) N, the pendulum will have a length of \(20\) m, and then we have the diameter of cable and the speed at which it was lowered. I am not sure if the last two are superfluous.
How does one tackle this type of problem?
Mathematics news on Phys.org
Use Young's modulus for steel.
It says that the young's modulus for steel is 200.
\omega_n = \sqrt{\frac{200A}{mL}}
where \(A\) is the cross sectional area and \(L\) is the length. So L = 20 and \(A = 0.000025\pi\). The mass is \(m = 9810/g \approx 1000\).
\omega_n = 0.000886227
This doesn't seem right.
Young's modulus for steel is 200 GPa.
From 9810 N you can find the mass of the ball by just dividing 9.81, and mas becomes simply 1000 kg. Now you can find Kinetic Energy of the ball. When the winch is suddenly stopped, the cable gets elongated and a potential energy develops which resist the ball. Now Youngs Modulus gives you the force applied on the cable which comes out as
F = (EA/L)*x=kx where E young's modulus (200 GPa), A area of the cable, L length of the cable, and x is the increment in length.
Elastic potential energy = kx*x/2
Equating with KE, you can get x which gives amplitude.
To find the period apply F=kx or T=2*pi*sqrt(m/k)
In my rough calculation period and amplitude comes about 0.19 sec and 0.035 mt. Best of luck.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
