Need a free backup program for Windows
For users seeking a free and user-friendly program for differential backups on Windows laptops, several options are discussed. "Karen's Replicator" is mentioned, though its current status is uncertain following the creator's passing. "FreeFileSync" is highlighted as a potential alternative, although there is limited familiarity with it. "Macrium Reflect Free" is noted for its effectiveness in performing differential and full backups, but it does not support incremental backups in its free version. The tool "robocopy" is also considered, but it lacks a graphical user interface and relies on command-line usage, which may not appeal to those preferring a simpler solution. Overall, the emphasis is on finding a straightforward program that allows for easy file comparison and backup without the need for encryption or complex command-line operations.
Doc Al
Mentor
I'm looking for a free (and simple to use!) program to do differential backups of my files on my Windows laptop. I don't want anything encrypted, just something that can compare files to the backup and add/subtract whatever's been changed.
Years ago, I used "Karen's Replicator". Not sure if that's been kept up to date (after Karen's death). I see something called FreeFileSync, but know nothing about it.
Suggestions?
Computer science news on Phys.org
I've been using Macrium Reflect Free (free version) for a while and so far, so good. The free version can only do differential (and of course full) and not incremental backups.
Is robocopy good enough?
I want to avoid command-line backup methods. (I'm lazy!)
Well, you can schedule the task. Then there is no user interface, graphical or otherwise.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
