Need a setup for a fiction problem
  • Thread starter Thread starter Kadaj
    Fiction
To solve the friction problem involving a large cube and a small cube, it's essential to analyze the forces acting on both cubes. The large cube, with a mass of 25 kg, is accelerated by a force P on a frictionless surface, while the small cube (4.0 kg) is at risk of sliding down due to gravity unless sufficient static friction is present. The coefficient of static friction between the cubes is 0.17, which is crucial for determining the minimum force P required to prevent sliding. Drawing free body diagrams (FBDs) for both cubes will help visualize the forces, including the normal force and weight acting on the small cube, which must be balanced for it to remain in static equilibrium. Ultimately, the force P must equal the normal force exerted by the small cube on the large cube to ensure stability.
Kadaj
Need a setup for a friction problem
I know the concept of this problem but i don't know how to set it up...
'A large cube (mass= 25 kg) being accelerated across a horizontal frictionless surface by a horizontal force P. A small cube (mass= 4.0 kg) is in contact with the front surface of the large cube and will slide downward unless P is sufficiently large. The coefficient of static friction between the cubes is 0.17. What is the smallest magnitude that P can have in order to keep the small cube from sliding downward?'
Thanks in advance
anyone please help me
P of the box needs to equal the normal force of the little box onto the big box. Draw two FBDs. On of a little box showing the effects of friction, a normal force and weight. Remember, the little box is in static equalibrium when referenced to the big box. The entire two box system may be accelerating due to force P but the comparison of the two boxs should help you figure this out.
Draw a FBD of the big box as well. The N of the little box onto the big one equals the N of the big box onto the little BTW.
Good luck.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
