Need conversion and specific heat?
In summary, the conversation discusses a hypothetical scenario involving an asteroid's impact on Earth and the resulting energy it would release into the atmosphere. The asteroid's orbital characteristics, physical characteristics, and kinetic energy are provided, as well as equations and attempts at finding a solution. The main question is how to convert kinetic energy directly into thermal energy and determine the amount of energy needed to raise Earth's atmosphere by 1 degree. This discussion is part of a research paper looking into the possible effects of asteroid impacts on climate change.
forumasker
It's not really homework its more of my own thing, but I don't know where else I'd put it
category Main belt (Flora family)
Orbital characteristics
Epoch 6 March 2006 (JD 2453800.5)
Aphelion 2.594 AU (388.102 Gm)
Perihelion 1.825 AU (272.985 Gm)
Semi-major axis 2.210 AU (330.544 Gm)
Eccentricity 0.174
Orbital period 3.28 a (1199.647 d)
Average orbital speed 19.88 km/s
Mean anomaly 53.057°
Inclination 4.102°
Longitude of ascending node 253.2lllll18°
Argument of perihelion 129.532°
Proper orbital elements
Physical characteristics
Dimensions 18.2×10.5×8.9 km [1]
Mean radius 6.1 km[2]
Mass 2–3×10^16 kg (estimate)
Mean density ~2.7 g/cm³ (estimate) [3]
Equatorial surface gravity ~0.002 m/s² (estimate)
Escape velocity ~0.006 km/s (estimate)
Rotation period 0.293 d (7.042 h) [4]
Albedo 0.22 [5]
Temperature ~181 K
max: 281 K (+8°C)
Spectral type S
Absolute magnitude (H) 11.46
1199.647*24 because 24 hours, then times 60 because 60 minutes in an hour,
then times another 60 because 60 seconds in a minute, and we get about
1.03*10^8 seconds.
19.88km/s-0km/s)/(1.03*10^8s-0s)= approximately 1.93^-7km/s/s
E(sub k) = 1/2mv^2
Kinetic energy = (1/2)(2.5*10^16kg)(19.88km/s)
E(sub k) = 1/2mv^2
(v2-v1)/(t2-t1)
and the other stuff I'm looking for
The solution is kind of what I'm asking for, I need a way to convert kinetic energy directly into thermal energy, and then I also need to find how much energy it takes to raise the entire Earth's atmosphere by 1 degree of something or 1 kelvin, preferably degree.
Eccentricity 0.174
Inclination 4.102°
Albedo 0.22 [5]
Temperature ~181 K
max: 281 K (+8°C)
Spectral type S
1.03*10^8 seconds.
E(sub k) = 1/2mv^2
E(sub k) = 1/2mv^2
(v2-v1)/(t2-t1)
Hi Forumasker, Welcome to Physics Forums.
It's not entirely clear what your problem statement is, but I can surmise that you're trying to determine how much heat energy would be end up in Earth's atmosphere due to an impact by a asteroid or comet. Is that true?
Rigorous analysis would be difficult because there are several potential paths for energy to take from such a collision depending upon its nature; Depending upon the size, composition, and initial speed of the body it may wholly or partially disintegrate in the atmosphere due to friction. A big bow-shock pressure wave in front of the body also stirs up the atmosphere mechanically. If a large portion of the body makes it to the surface and undergoes "lithobraking", then its KE is dumped into the Earths surface via a cratering event. Some portion of that energy will still make it into the atmosphere as the "hot spot" cools.
The body for which you've provided data doesn't cross the Earth's orbit: it has a perihelion of 1.825 AU compared to the Earth's 1 AU nearly circular orbit. Perhaps you're just looking for sample characteristics for estimation purposes?
Supposing that the body was somehow perturbed into crossing the Earth's path, it's orbital velocity would be a function of its position in its orbit (distance from the Sun). You can work out its speed for any distance from the Sun using the concept of conservation of total mechanical energy. The total mechanical energy held by anybody in orbit around the Sun is
inversely proportional to the length of the body's major axis: ##\xi = -\mu/(2a)##.
If the body is "captured" by the Earth then it will gain additional energy from gravitational potential energy converted to kinetic energy as it falls into the Earth's local gravitational well. Whether or not this will be a significant contribution will depend upon the initial speed of the body w.r.t. the Earth -- is the body approaching the Earth "from behind" (prograde orbit) or from "in front" (retrograde orbit) or perhaps its trajectory is nearly perpendicular to the plane of the Earth's orbit? Maybe you're just looking for the maximum approach speed?
You should be able to search the web for values for the specific heat of air, as well as total mass estimates and volume of the atmosphere.
The atmosphere is in a container whose "lid" is provided by gravity. That means when energy is added it will not only go into raising its temperature but also expanding the atmosphere against its "lid" -- The atmospheric volume will get larger. So adding energy to the atmosphere is not quite the same thing as adding energy to air sealed in a fixed size container. For a given "dose" of energy, temperature changes will be moderated by some energy going into gravitational potential energy as the atmosphere expands.
Thank you, but I'm already aware of all of the factors, this a hypothetical. Answers would be much appreciated, such as how to directly convert kinetic energy to thermal energy, which I suppose is mostly through friction, as well as finding out how much energy it takes to heat Earth's atmosphere 1 degree. This is mostly for my research paper which I predict I will have to do at the end of the year but don't know for sure if I will have on theoretical physics and research, and I'm trying to see if asteroids/meteoroids could possibly account for any climate change, and the total amount of asteroid debris that has hit/entered the Earth in the past few years may be well over or under 10^16kg, but the asteroid I'm using is sort of a reference to see what happens if we can actually see what all that debris does in one single moment. 951 Gaspara just to see if all that energy was converted into thermal energy, since most asteroids that enter Earth's atmosphere aren't asteroids at all, they are meteoroids which are grains of dust and completely burn up upon entry, and because of that, most or at least 99.99 percent of a meteoroid's kinetic energy is converted into thermal energy via friction. So I'm just seeing "what happens if the amount of mass in Gaspara just "burned up" upon entry.
And then, I need to I guess use specific heat or some way see how much Earth's atmosphere heat's up when it absorbs all of that thermal energy, which may or may not be a lot, so I need someway to see how much all that energy raises the temperature of Earth's atmosphere.
I mean Hurricane Katrina contained over 180 atomic bombs of energy, so this theory isn't really looking good right now.
FAQ: Need conversion and specific heat?
What is need conversion and why is it important in science?
Need conversion is the process of converting one unit of measurement into another. It is important in science because it allows for consistency and accuracy in measurements, which is crucial for conducting experiments and analyzing data.
2. How is need conversion related to specific heat?
Specific heat is a measure of the amount of heat required to raise the temperature of a substance by a certain amount. It is often expressed in terms of energy per unit mass. Need conversion is used to convert between different units of energy and mass, which are important for calculating specific heat.
3. What are the most commonly used units for specific heat?
The most commonly used units for specific heat are joules per gram kelvin (J/g*K) and calories per gram kelvin (cal/g*K). However, other units such as kilojoules per kilogram kelvin (kJ/kg*K) and BTUs per pound degree Fahrenheit (BTU/lb*°F) may also be used.
4. How do I convert specific heat from one unit to another?
To convert specific heat from one unit to another, you can use conversion factors. For example, to convert from J/g*K to cal/g*K, you can multiply the value in J/g*K by 0.239 to get the equivalent value in cal/g*K. Alternatively, you can use online conversion calculators or tables for more complex conversions.
5. Why do different substances have different specific heats?
Different substances have different specific heats because the amount of energy required to raise the temperature of a substance by a certain amount depends on its molecular structure and composition. Substances with stronger molecular bonds and higher molecular masses tend to have higher specific heats, as they require more energy to increase their temperature.
