Need help calculating bearing life for gearbox in mixer application?
  • Thread starter Thread starter SevenToFive
    Bearing Life
Calculating bearing life for a gearbox in a mixer application requires specific information beyond just motor power and torque ratings. Essential data includes actual and worst-case loadings, which can be visualized through a free body diagram detailing all forces acting on the output shaft. The bearing life should be calculated at both design and worst-case loads, followed by discussions with stakeholders to determine if the design meets requirements. If the design life is inadequate, a redesign may be necessary, or management might opt for cost reductions. Understanding bearing types and their specifications is crucial for accurate calculations.
SevenToFive
TL;DR Summary
How do I calculate bearing life with provided data?
I am a little confused on how to calculate the bearing rating and life for a gearbox in a mixer application. The only information that they are providing is the following, using a 1/4HP motor, 0.08 HP expected loading, a max torque of 87.2 in-lbs, 175.8 in-lbs bending max, and 632 psi expected bearing stress.
Wouldn't I need to know the run time(hours)? I feel that I am missing some information to help me set up the equations. Could someone please help me out. Thank you in advance.
The numbers that you presented are not enough information to do any calculations. You need to find the actual and worst case loadings, then put together a free body diagram (search the term) showing all of the loads on the output shaft. That diagram will include the loads from the impeller, the loads from the driven gear, and the bearing loads. That, plus the output shaft RPM, allows you to calculate the design life of the bearings supporting the output shaft.
You calculate the bearing life at the design load.
Then you calculate the bearing life at the worst case load.
Then you discuss the results with the other people concerned, starting with your supervisor.
Then the decision is made as to whether the design life is good enough.
If not, somebody needs to redesign something.
Or management may decide that it will last too long, in which case it will be redesigned to reduce cost.
Hint: Worst case loading is the peak torque of the motor.
Hint: Do NOT try to speed the process by skipping the FBD.
Likes berkeman
For a start, type of bearing, i.e. lubricated sleeve (if so, then the bearing material) or roller/ball bearing and the rpm of the shaft.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
