Need Help finding theoretical and actual acceleration (Atwood)
In summary: That will help you understand what equation to use.In summary, an atwood machine lab has given the masses and time it takes the heavier mass to hit the ground from a distance. The experimental acceleration was found to be .697m/s/s, while the theoretical acceleration was found to be 1.4m/s/s. However, there are uncertainties in the measurements, and air resistance and the atwood machine may not be a good one. Additionally, the equation for uniformly accelerated motion does not use space.
Student7987
So, I have an atwood machine lab. What I have been given is the masses of either end and time it takes the heavier mass to hit the ground from a distance.
M1= .2kg
M2 = .15kg
avg time = 1.12 sec
What i think I have to do: To find the actual acceleration I have to use v = vi + at and solve for acceleration.
To find theoretical acceleration, I have to use a = ( (M2-M1) (g) )/ (M1+M2).
Theoretical: 1.4m/s/s
Actual: .697m/s/s
Kindly tell me if I am doing this right or not and how should I go about doing it correctly. It seems like these values I've obtained are incorrect and I'm missing something considering I didn't go into the topic we are studying very much. No use of free body diagrams or even sum of forces.
Thanks.
One important thing you missed is the uncertainties in your measurements. If they are high enough, you can say those accelerations are in agreement within the uncertainties!
The other point is, you missed air resistance. Also your atwood machine may not be a good one! And many other things that only you, the experimenter, can tell because you know how is the situation around the machine and with the machine itself.
Welcome to PF!
I am not sure how you calculated the "experimental" acceleration. What was the height the bigger mass fall from in 1.12 s?
ehild
What did you use for the velocities here? If you used vi = 0 and the average velocity for v, then your result will be off by a factor of 2 (which seems deceptively similar to what you have).
I'm sorry I forgot to mention a few things. The greater mass was positioned .875 meters off the ground. The second mass, when the greater mass was released traveled those .875 meters up. There is no air resistance as well.
V=vi+at was supposed to be
.781 (distance/time) = 0 +a(1.12)
So what would I use for v if not the average. I don't even think I used the right formula.
There's an equation for uniformly accelerated motion that relates acceleration, space, and time... Use it...
To add to what NTW just said: The equation you quoted is an expression for the velocity at time t while what you were using was the average velocity between 0 and 1.12 s. However, using the expression for the velocity at time t, you could relatively easy deduce the average velocity between two given times (in particular since the velocity in this case depends linearly on the time).
I'm still not sure what equation using space you are talking about though. But from what we were taught in AP Physics 1 (Current class) there was no equation using space. Are there other acceleration equations using distance, time, and mass.
Also I haven't use the sum of forces at all yet but I'm guessing it ties into my theoretical acceleration equation
Let me again suggest that you think about how the average velocity is related to the final velocity in a system with constant acceleration.
Related to Need Help finding theoretical and actual acceleration (Atwood)
1. What is the Atwood machine?
The Atwood machine is a simple mechanical device used to study the effects of acceleration and mass on an object. It consists of two masses connected by a string or rope, with one mass hanging over a pulley.
2. How do you calculate theoretical acceleration in an Atwood machine?
The theoretical acceleration in an Atwood machine can be calculated using the formula a = (m1 - m2)g / (m1 + m2), where m1 and m2 are the masses of the two objects and g is the acceleration due to gravity.
3. How do you determine the actual acceleration in an Atwood machine experiment?
The actual acceleration in an Atwood machine experiment can be determined by measuring the time it takes for the masses to move a certain distance and using the equation a = 2d / t^2, where d is the distance and t is the time.
4. What factors can affect the results of an Atwood machine experiment?
Some factors that can affect the results of an Atwood machine experiment include friction in the pulley, air resistance, and human error in measuring the time and distance.
5. How can you improve the accuracy of an Atwood machine experiment?
To improve the accuracy of an Atwood machine experiment, you can reduce sources of error by using a low-friction pulley, minimizing air resistance, and taking multiple measurements and averaging the results.
14K
