Need help for a statistical tool for my test
  • Thread starter Thread starter mark.ramos
    Statistical Test
A software programmer seeks advice on statistical tools for performance analysis and accurate payment computation in their software. They are considering using a chi-square test but are unsure if it is appropriate, given their expected outcomes of "Accurate" or "Not Accurate." The programmer manually computes values to verify accuracy against the system's results. Suggestions include defining accuracy criteria, using confidence intervals, and conducting goodness-of-fit tests to assess the module's performance. The discussion emphasizes the need for clarity in defining accuracy and selecting suitable statistical methods for validation.
mark.ramos
Hi!
I am a software programmer and I would like to make a performance analysis of my software. One of the objectives that we need to achieve is to create a module for accurately computing the payment. Now, my expected result is that all computations are accurate. What statistical tool should I use to support my observations. I am confused in using a chi-square test for this. The expected outcomes are either Accurate or Not Accurate. Since I assume that my computations are accurate, the frequency that I set for accurate is 10 and 0 for not accurate in the case of 10 trials. I hope someone can help me on this one.
Thank you!
Mathematics news on Phys.org
So you have a binomial distribution?
What information do you have? How do you tell if a calculation was accurate or not?
Well, to test if it is accurate, I first compute it manually (without the system) then I compare the computed value of the system and if it matches my manual computation I consider it accurate. By the way I would like to know what statistical test should I use if I want to determine if a module is working or not. Like I have an objective that I should create a module for generating reports, and I have to make a test that will support that I have achieved my objectives. What test should I use?
Thank you!
So you have 2 sets of data:
1) calculations from your program
2) handmade calculations
and you want to check it's accuracy, right?
My thoughts: (i'm not advanced in statistics though):
1) define what's 'accurate' (5% error?)
2) If you want to then define 'Confidence interval' and do some basic test or as you have written do some 'Goodness of fit' test (you can support it with p-value test, but it will probably give you the information: 'your hipothesis cannot be rejected' ...)
but let's wait till somebody wiser give you better answer;)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
