Need help understanding off axis electromagnet field strength equation
The discussion centers on understanding the off-axis magnetic field strength equation for electromagnets, specifically how to apply polynomial equations for accurate measurements. The original poster attempted to use the equation up to the 8th power but found that the calculated field strength increased unrealistically at distances from the solenoid. Responses clarify that the polynomial approximations are only valid inside the solenoid, leading to erroneous results when applied outside this region. The poster seeks an alternative equation for calculating field strength beyond the solenoid's central core. Accurate modeling of magnetic fields requires careful consideration of the applicable regions for the equations used.
Jake110
I have this equation for the magnetic field strength of an electromagnet but it’s in the form of multiple polynomials. Here is the page where they all are:
http://www.netdenizen.com/emagnet/offaxis/solenoidoffaxis.htm
since it gives values for e_8 and p_8 I tried using the main equation up to the 8th power but when I plotted the parallel distance against the field strength I found that it increases drastically to the point where at 5cm away the field strength is 1 Tesla (the strength I already know is B_0 which is the strength at the centre of the electromagnet and that’s only 0.03 Tesla)
So obviously the way I tried using it is wrong because the field strength should decrease the further away your measuring.
Can anyone help me figure out how to use this equation?
Read the page you linked carefully. Note that the polynomial represents approximately field strengths INSIDE the solenoid. As you have discovered, if you extrapolate polynomial approximations outside of the region it represents the values obtained become meaningless very fast,
damit, you wouldn't happen to know an equation for the field strength outside the central core would you?
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
