Need Help with Abstract Algebra Please
Redhead711
My question is regarding abstract algebra.
Suppost that B is a 10-cycle.
For which integers i between 2 and 10 is
B^(i) also a 10-cycle?
I know that the answer is 3, 7, and 9 I just don't know
how you arrive at these numbers. If someone could explain the
process clearly to me I would greatly appreciate that.
Thank you sooo much. :-)
The i are values that are coprime (have no common factors other than 1) with 10.
Here's a general proof:
Let's say we have some element g with order n. Then g^i has order \frac{n}{<n,i>} where <n,i> is the greatest common factor of n and i.
Proof:
({g^{i}})^{\frac{n}{<n,i>}}=g^{i \times \frac{n}{<n,i>}}
but
i = k \times <n,i>
for some k so
g^{i \times \frac{n}{<n,i>}}=g^{k \times <n,i> \times \frac{n}{<n,i>}}=g^{k \times n}=g^{n\times k}=(g^{n})^{k}=e^k=e
so the order ok g{i} is at most \frac{n}{<n,i>}
Now, let's say we have some j so that
e=({g^{i}})^j=g^{ij}
then, since the order of g is n
so n | ij (n divides ij)
so \frac{n}{<n,j>} | j \Rightarrow j \geq \frac{n}{<n,i>}
So the order of g^i is \frac{n}{<n,i>}.
In this particular case, you have \frac{n}{<n,i>} = n so <n,i>=1.
Thank you so much I understand much better now. I am very grateful for all your help.
I think that g has order 10 does not guarantee that g is a 10-cycle. If g is a product of two disjoint cycles of order 2 and 5, it can still have order 10. Is that right?
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
