Need help with electric field/potential problem
  • Thread starter Thread starter lunarskull
    Electric
The discussion centers on calculating local surface charge density on an irregularly shaped conductor, given electric field values of 56 kN/C and 28 kN/C. The challenge arises from the limited information provided, leading to confusion about how to manipulate these values to find the charge density. A key point is understanding the relationship between electric field (E) and surface charge density (σ), particularly that σ is higher at points of low curvature. Ultimately, the user was able to resolve their confusion and understand the problem better with guidance on the foundational concepts. The thread highlights the importance of clarity in physics problems involving irregular shapes and electric fields.
lunarskull
The problem is defined below:
The electric field on the surface of an irregularly shaped conductor varies from 56 kn/c to 28 kn/c. calculate the local surface charge density at the point on the surface where the radius of curvature of the surface is (a) greatest and (b) smallest.
Attempt at a solution:
Yet to start, b/c don't understand any further steps with such little information
Extra question:
If they only give us 2 numbers of an irregularly shaped object, how are we supposed to manipulate these numbers to find the local surface charge density?
There is a formula connecting E immediately outside the surface of a conductor and sigma (surface charge density). You also should know where the sigma is higher, that is, at points of low or high curvature.
thank you for the help, i eventually figured it out because you gave me the general basis that i needed to understand how to answer the problem
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
