Need Help With Guass Laws and Amperes Law
The discussion revolves around solving problems related to Gauss's Law and Ampere's Law involving a point charge and a spherical conductor. The user seeks step-by-step guidance to understand the electric fields in three regions surrounding the charge and conductor. Key points include determining the charge within Gaussian surfaces and recognizing that the electric field inside a conductor is zero. The conversation emphasizes the importance of correctly identifying charges in different regions to apply Gauss's Law effectively. Overall, the user gains clarity on the concepts and calculations needed to solve the problems.
AdiV
Hi, I am really stuck with these problems, is it possible you guys can help me out, by guiding me along this problem, I wil write the entire thing out, but would appreciate it if you guys help me step by step so that I can understand it, since I am having a VERY hard time with these problems.
A point charge (+q) is located at the origin. A spherical conductor of inner radius "a" and outer radius "b" surrounds this point charge with its center at the origin. A total charge of =2q lies on this spherical conductor.
{I put the diagram as an attachment}
a) Find the magnitude of the electric field in region I, at a distance r<a away from the origin. Label on the diagram some E field line within this region, if necessary. [Hint: Use Guass Laws]
b) Find the magnitude of the electric field in region II, at a distance r>1 (but <b), from the origin. Again label on the diagram some E fields if necessary.
c) Find the magnitude of the electric field in region III, at a distance r>b from teh origin. Again label on the diagram E field lines if necesary.
Consider 2 different designs for a printer cable. Design 1 has 4 cables each carrying a current I into the page. Design 2 has 4 cables all carrying current magnitude I but two have the current in one direction and two have in the opposite direction.
d) Find the magnetic field at a distance r. (in the plane which is perpendicular to the wires), away from cable 1 by using Ampere's Law.
e) Find the magnetic field a distance r away from cable 2 by using AMpere's LAw.
f) Which design is better, why?
Guass Law;
\Sigma Eperp * delta A = Qenclosed / \epsilon0
Ampere's Law;
\Sigma Bparallel * delta l = \mu0 * Ienclosed
Again, thank you for the help here.
Ok, I 've been working on it and well, I got to this point, but am not too sure.
a) sigma E perpendicular delta A = E * sigma delta A = E(4*pi*r^2) = Q / epsilon
So wouldn't the charge in section I be +q / epsilon?
c) sigma E perpendicular to delta A = E * sigma A = E * (4 pi r^2) = Q / epsilon
so E = 1 / [4 pi r^2] * Q / b
so, doesn't this tell us that the field outside the uniformly charged spherical shell is the same as if all the charge were concentrated at the center as a point charge??
So that would mean that it is -2q?
I am not too sure
The charge contained within that surface is given as +q. So solve for E.
That's correct. (The formula has a typo: You have b instead of epsilon.)
What's the total charge within the Gaussian surface when r > b?
The total charge is + q?
Can we go over this a bit more? I am really feeling lost right now.
To find the total charge within a surface with r > b, just add the charge at the center (+q) to the charge on the conductor. (What's the charge on the conductor?)
The charge on the conductor is -2q, so +q + -2q will be -q so that is the charge in region I?
No, that's the charge within a sphere of radius r > b. Region I is within r < a; the only charge in that region is the center charge of +q.
Note: The regions are for the purpose of defining the field. For finding the charge, use a Gaussian sphere of the appropriate radius, counting all the charge within that radius.
Ohh, ok, I think I understand now, so for region II the charge would be -2q since that is the charge of the conductor
Careful here: What's the field in region II? (Hint: What's the field within a conductor?)
While the total charge on the conductor is -2q, where is that charge located? What's the charge on its inner surface? Its outer surface?
The E field in a conductor is zero right?
Exactly. So part (b) is easy.
Wow, thank you so much!
Just to prove to yourself that you fully understand it, try to answer my other questions in post #9. (Use Gauss's law.)
