MHB Need help with Physics with trigonometry problems ?
The discussion focuses on solving a physics problem involving trigonometry and fluid dynamics related to Hurricane Michael's wind pressure on a building's roof. The user initially calculates the pressure difference using Bernoulli's equation, arriving at a result of 3070 PA, and seeks confirmation of their approach before proceeding to subsequent questions. Another participant confirms the calculation is correct and provides a video resource for further understanding. The user expresses gratitude and feels more confident about tackling the remaining questions. Overall, the thread emphasizes collaborative problem-solving in physics.
gamergirlxoxox
3) Hurricane Michael had horizontal winds of Vout = 69 m/s (155 mph). Pair = 1.29 kg/m3. A building with a flat, horizontal roof, Aroof = 200 m2, and Vin = 0 m/s.
a) What is the pressure difference, Pin - Pout on the roof. Assume Yin = Yout.
b) What is the force acting on the roof, and what is the direction of this force ?
c) What is this force in pounds ? 1 N = .225 lb.
After the storm, it is found that a small object has been driven into the water tower. The water level inside the water tower is 12 meters above the ground. The height of the hole is 9 meters above the ground. The object is removed and water sprays out.
d) Considering the hole and the tower, what is the speed of the water coming out of the hole ? Assume Vin = 0 and Pin = Pout = Patm.
e) If the hole is 9 meters above the ground, how long does it take the water to hit the ground ?
f) With the speed the water has, and the time to hit the ground, how far does it travel horizontally ?
So, I'm not sure if I did it right but what I did for part A was use the Bernoulli's equation:
P1 + 1/2pv1= P2 + 1/2pv2
Delta P (P2-P1)= 1/2pv21 - 1/2pv22
Delta P = 1/2p (V21 - V22)
Delta P = 1/2 (1.29 kg/m3) (692 m/s - 02 m/s)
Delta P = 3070 PA
I'm not sure if I'm correct though so I didn't really attempt to do the other questions to this problem in case I'm wrong.. I'll gladly appreciate it if someone could help me out.
Mathematics news on Phys.org
Hey gamergirlxoxox! Welcome to MHB! ;)
You are entirely correct.
Here's a video where it's explained:
[YOUTUBE]cUMspps8d8A[/YOUTUBE]
Thanks ! I think I can probably figure the rest out now
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
