Need help with replacing a lead-acid sealed battery with a Lithium Ion battery
Replacing a 12v 5Ah lead-acid battery with a 14.8v 6600mAh lithium-ion battery may not work due to potential voltage compatibility issues with the motor's protection circuit. Users are cautioned against using the same charger for both battery types due to fire hazards. The lithium battery appears to run the motor briefly before failing, indicating possible current limiting or a dead battery issue. Measuring the terminal voltage during operation can help diagnose the problem, especially if it drops to zero. A smaller voltage battery may be a viable alternative if compatibility issues persist.
banglour
What I am trying to do is replace my 12v 5Ah lead-acid battery with a 14.8v 6600mAh lithium ion battery. It powers a small fan belt. And for some reason I can't get the lithium battery to work. Can somebody tell me what I might be doing wrong, or if it will even work?
#1: Do NOT charge the Lithium battery with the same charger used for the Lead-Acid battery! This is a potential fire and/or explosion hazard!
As for the problem you're having... assuming the Lithium battery is fully charged, it's possible that the motor has a protection circuit that doesn't like the higher voltage. What exactly happens when you connect the new battery? Does it run if you reconnect the lead-acid battery?
Yes I have a separate charger just for the Lithium battery.
The battery is fully charges and when I connect the lithium battery and turn the motor on it sounds like it actual runs, but just for a split second. Then nothing happens after that. When I connect the lead-acid back up the motor runs just fine. Why is that?
Sounds some form of protection circuit either in the battery pack or in the motor (or of course a dead battery).
Can you please measure the terminal voltage while you test it. If the terminal voltage drops markedly when the motor stops ("after a split second") then there is a problem with the battery. Either a dead battery or some built in current limiting.
After I start the motor the terminal voltage drops all the way to 00.0. I have a hard time believing that its a dead battery because its brand new. Would it work if I got a smaller Voltage battery?
Do you have any specifications on the battery pack. Does it have any built in over-current proctection?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
