Need some help with this Physics problem
  • Thread starter Thread starter Kadaj
    Physics
The discussion revolves around solving a physics problem involving magnetic and electric fields, as well as the tension in strings. The original poster struggles with the calculations related to the forces acting on wires due to tension and magnetic repulsion. They calculate a current of 91.8A and a horizontal force of 1.29, but seek confirmation on their approach and results. Respondents advise checking the calculations, particularly the units for the horizontal force, and provide insights on the relationships between tension, weight, and forces. Accurate calculations are emphasized as crucial for verifying the solution.
Kadaj
Hi,
I have a problem here that I'm having trouble with, I attempted to do it by using equations dealing with magnetic fields and electric fields, but then i had to consider the tensions of the strings and the components and became lost. Can anyone help me?
Thanks in advance,
Here is the problem:
http://img.villagephotos.com/p/2004-9/824584/stupid5.jpg
Thanks again
Consider the weight of some length of the wires. The tension in the string has to support the weight and pull the wires together. If T is the tension, the weight is T cos (7.5) and the horizontal force is T sin (7.5) The horizontal force from the tension is equal to the force of repulsion due to the currents.
ok, I did what you said and got the current as 91.8A, but is this right? I found the horizontal force to be 1.29 and the length between the wires to be .0259 meters, then i used the equation, F/L= (permeability of freespace)(I^2)/ 2(pi)r, and I took the force and multipled it by the .050 kg/m then solved for the I in the equation. Is this right? or is there something I;m doing wrong.
Thanks for the help
Chances are pretty good when you do a multiple choice question and get exactly one of the answers, you have done it right. You have the right equation for F/L. I don't know what your units are for a horizontal force of 1.29. Do you mean force per unit length in N/m? Something else? I don't see 1.29 coming out of the numbers. The horizontal force on each wire is about .132 times the weight, with the tension in the string being about 1.00863 times the weight. Check your calculations, and then believe them.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
