- 2,810
- 605
Shyan submitted a new PF Insights post
Negative absolute temperatures
Continue reading the Original PF Insights Post.
Why you haven't made specific examples of systems having negative absolute temperaure, as a Laser pump system where population invertion is in act? While internal energy increases, in that system, entropy decreases.Shyan said:Shyan submitted a new PF Insights post
Lasers are not examples of what I described. The population inversion in lasers happens as a non-equilibrium state while negative temperature states are equilibrium states.lightarrow said:Why you haven't made specific examples of systems having negative absolute temperaure, as a Laser pump system where population invertion is in act? While internal energy increases, in that system, entropy decreases.
Regards,
lightarrow
Ok, thank you!Shyan said:Lasers are not examples of what I described. The population inversion in lasers happens as a non-equilibrium state while negative temperature states are equilibrium states.
Negative absolute temperatures refer to a state in which a system has more energy in its lower energy states than in its higher energy states. This is in contrast to our everyday understanding of temperature, where higher temperatures correspond to higher energy states.
Negative absolute temperatures are possible because of the way temperature is defined in thermodynamics. Temperature is not just a measure of energy, but also a measure of the probability of a system being in a particular energy state. When the probability of a system being in a higher energy state is greater than the probability of being in a lower energy state, the temperature becomes negative.
One example of a system with a negative absolute temperature is a group of atoms in a laser. In this case, the atoms are in a highly excited state, with a greater probability of being in their higher energy states. This creates a negative temperature, which is necessary for the operation of a laser.
Negative absolute temperatures have several implications in the field of physics. They can be used to create systems with negative specific heat, which means that they get colder as you add energy to them. They can also be used to study and understand quantum systems, as they are often found in systems with low temperatures and high energy states.
No, negative absolute temperatures cannot be reached in everyday objects. These temperatures are only possible in highly controlled and specialized systems, such as lasers and certain quantum systems. In everyday objects, the temperature scale only goes down to absolute zero, which is the point at which all molecular motion stops.
