- #36
- 23,434
- 5,748
Yes, provided the delta T of the water is virtually zero. Otherwise, the final reactor temperature will not be the same in the two cases. So the reactor would have a different entropy change.wvphysicist said:I have two questions about closed systems. Consider two closed systems, both have a chemical reaction area which releases a small amount of heat and are initially at the freezing point. One has water and no ice and the other has ice. I expect after the chemical reaction the water system will absorb the heat with a tiny change in temperature and the other will convert a small amount of ice to water. Is there any difference in the increase of energy? Suppose I choose masses to enable the delta T of the water system to go toward zero. Is there any difference?
I don't have a clear idea of what this equation is about. Let me try to articulate my understanding, and you can then correct it. You have an isolated system containing an exothermic chemical reaction vessel in contact with a cold bath. In one case, the bath contains ice floating in water at 0 C. In the other case, the bath contains only water at 0 C. Is there a difference in the energy transferred from the reaction vessel to the bath in the two cases. How is this affected if the amount of water in the second case is increased? (Are you also asking about the entropy changes in these cases?)
Using identical reaction vessels the energy transferred is set the same. The question is about the entropy change. Will heating water a tiny delta T or melting ice result in the same entropy change?
Chet
