Negative area above x-axis from integrating x^2?
In summary: The value of an area depends on the coordinate system we are using, while the value of an integral is always positive.
member 731016
TL;DR Summary
I am interested whether we can get a negative area above the x-axis when the lower limit of integration is larger than the upper limit of integration
Suppose the following integration,
##\int_3^{-1} x^2 \, dx = \frac{1}{3}(-1)^3 - \frac{1}{3}(3)^3 = -\frac{28}{3}##
However, if we have a look at the graph,
The area between ##x = 3## and ##x = -1## is above the x-axis so should be positive. Dose anybody please know why the I am getting negative area from the integral?
Many thanks!
Integrals are oriented areas. ##\int_a^b f(x)\,dx =-\int_b^a f(x)\,dx.## So it has an opposite sign if you integrate from left to right or from right to left.
Likes vanhees71 and member 731016
Thank you for your reply @fresh_42 !
That is very helpful! Does this mean since the integral is negative, then the area is negative, so we can have negative area above the x-axis (without going below the x-axis)?
Many thanks!
ChiralSuperfields said:
Suppose the following integration, ##\int_3^{-1} x^2 \, dx = \frac{1}{3}(-1)^3 - \frac{1}{3}(3)^3 = -\frac{28}{3}##
No. The left-most integral above has the limits of integration in the wrong order, so the value of the integral will be negative, as you found. If you rewrite the limits in the proper order -- left to right or bottom to top, then you'll get a positive value.
Your integral should have its limits like so: ##\int_{-1}^3 x^2 \, dx##.
Likes member 731016
Many thanks!
It means that we need to be very careful when we consider the value of an integral as an area.
If ##F(x)## is the anti-derivative of ##f(x),## i.e. ##F(x)'=f(x)## or ##\int f(x)\,dx=F(x), ## then
\int_a^b f(x)\,dx=F(b)-F(a)\text{ or } \int_a^a f(x)\,dx=\int_a^bf(x)\,dx +\int_b^a f(x)\,dx= 0
The integral also makes a difference between above and below the ##x##-axis.
Example:
\int_{-90°}^{90°} \sin(x)\,dx =\left[-\cos(x)\right]_{-90°}^{90°}=- \cos( 90°) -(- \cos (-90°) )=-0+(-0)=0
But the area is not zero, it is
\begin{align*}
&\text{Area below the sine curve from }-90°\text{ to } +90°=\left|\int_{-90°}^{0°} \sin(x)\,dx\right|+\left|\int_{0°}^{90°} \sin(x)\,dx\right|\\
&=|-\cos(0°)+\cos(-90°)|+|-\cos(90°)+\cos(0°)|\\
&=|-1+0|+|-0+1|=|-1|+|1|=2
\end{align*}
Areas are always positive, integrals not necessarily. The sign of an integral depends on which quadrant of the ##(x,y)##-plane we are in, and whether our integration is clockwise or counterclockwise. To calculate an area, we have to split an integral into portions. Say ##a < c <b## and ##f(c)=0.## then the area below ##f(x)## is given as
A=\left|\int_a^c f(x)\,dx \right|+\left| \int_c^b f(x)\,dx\right|
There is just a difference between an area and an integral.
Likes member 731016
  • Calculus
  • Calculus
