Negative feedback - Open loop gain question
Understanding negative feedback requires recognizing how resistors RE1, RF, and RE2 affect open loop gain in amplifiers. These resistors load the amplifier, which influences the overall gain. To convert circuit(a) to circuit(b), one must determine the resistance from the emitter of Q1 and Q3 to ground. The confusion often arises from the interpretation of "open loop," which may suggest removing feedback components. Acknowledging the role of these resistors clarifies their importance in calculating open loop gain.
okami11408
This is my first post here.
I'm currently learning about Negative feedback.
Normally, When we want to know the open loop gain, we rewrite circuit(a) to circuit(b).
My question is why do RE1,RF,RE2 from circuit(a) turn into what we see circuit(b)?
what is a theory behind this?
In my opinion, if we want to find the openloop gain, why don't we just take the RF out.
I may misunderstand something, please help!
Here's the image.
http://forum.allaboutcircuits.com/cache.php?url=http://img821.imageshack.us/img821/1626/60542118.jpg
We need to include this resistors into account for one simple reason.
Those resistor load our amplifier. So the Open loop gain will change.
And to change circuit(a) into circuit(b) we simply need to find the resistance seen from emitter Q1 terminal into the ground. And the resistance seen from Q3 emitter into the GND.
Now I got it. Those resistor load our amplifier too.
The reason why I confuse is I think "open loop" maybe something like we take the feedback circuit out of the circuit.
Thank you so much :-p
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
