Neutron star spin and rotation axis
Neutron stars emit beams that appear as pulses due to their rotation, with these beams not aligned with their rotation axis. Current theories suggest that neutron stars can spin rapidly, potentially at rates like 600 times per second, while also having a secondary axis of rotation. The magnetic fields of neutron stars are typically offset from their spin axis, akin to Earth's magnetic field misalignment with true north. This raises questions about the stability and wobbling of their rotation in space. Understanding these dynamics is crucial for comprehending neutron star behavior and their magnetic properties.
pmghss
Neutron stars are thought to be rotating in a way that their beems are seen as the pulses. The beems are not aligned with the axis of rotation. What is the current theory about the speed of the axis of rotation? Are they spinning and rotating on both axis?
Astronomy news on Phys.org
Drakkith said:
The magnetic fields of the Neutron stars are offset from their axis of spin similar to how the Earth's magnetic field is offset from true north/south.
See here: http://en.wikipedia.org/wiki/File:Pulsar_schematic.svg
The star is spinning in a way that we are seeing it's polar axis, or close to it.
If one is spinning in that manner at 600 times a second for example, what about it's other axis of rotation? The "daily" axis of rotation. Is it wobling through space?
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
