New High Efficiency Power Lines
Recent discussions highlight advancements in high-efficiency power lines, particularly superconducting and high-voltage direct current (HVDC) technologies. While superconducting wires are not yet practical, HVDC systems are recognized for their ability to resolve stabilization issues associated with three-phase alternating current (3PH AC) transmission. The potential for increased capacity is significant, especially during peak demand periods, although challenges remain regarding conductor design and environmental factors. Future HVDC lines in Australia are expected to enhance connectivity between states and integrate renewable energy sources more effectively. Overall, there is a consensus that while progress is being made, practical implementation is still in development.
I read an interesting article on progress in making transmission lines more efficient:
https://reneweconomy.com.au/super-c...-capacity-and-open-floodgates-for-renewables/
While, of course, we do not discuss politics here, this new technology has many advantages. When I read about it, I thought, why isn't everybody doing it? It looks like a no-brainer.
The question is, am I missing something, or is this something that is happening without fanfare?
Thanks
Bill
Tell him he is dreaming.
Superconducting wires are not yet realistic.
We need more than a 30% increase, we need a factor of two or three at least.
The article assumes 3PH AC transmission. That leads to stabilisation and regulation problems between states, which is acknowledged.
When HV DC transmission lines are implemented, those problems will be gone. The conversion stations at the ends of the HV DC lines handle the phase and voltage differences.
  • Love
Likes Rive, sophiecentaur, DaveE and 1 other person
High voltage DC links in Europe have ben used successfully for a long time. We're all hanging on for the arrival of suitable superconductors.
On the topic of electrical power distribution, there was an episode of 'In Our Time', which is a weekly BBC R4 programme. It discusses the life and times of Nicola Tesla and the Battle between AC and DC, a century ago. All the same factors were at work back then - only the nujmbers were different. It's well worth a listen and puts Tesla in his deserved place - an inspired inventor who was deified by too many people.
Likes bhobba and Rive
It's about a missing link between the article and reality.
...and at this point please allow me to recite again the tale about the Great Central European Loop Flow and the Heroic Band of DC-links and PSTs around Germany what finally slain that Great Evil o0)
Likes sophiecentaur and bhobba
Increasing capacity, when air temperature is lower than normal, is only advantageous during peak demand. The peak demand on Australia's transmission lines is in the afternoon, during heatwaves, when temperatures and air conditioning loads are already at a maximum. Maybe that will change sometime, with more local solar panels powering the local AC.
If you look along a transmission line during a strong wind, you will see the side force due to aerodynamic wind drag are greater than the conductor weight due to gravity. For that reason, increasing the diameter of the cable for the same weight, would significantly increase the wind forces on the insulators and towers, which is the vector sum of wind and gravity.
By changing from a solid conductor, to a bundle of four wires, as an open cage, wind drag could be maintained, and the current increased with better cooling.
Taking advantage of the cage, by increasing the voltage on the line, is precluded by the length of the insulators, and the tower dimensions.
Wherever possible, HVDC links are installed underwater, where the cooling is predictable, and not determined by heatwaves and winds. In Australia, I would expect future HVDC lines, to cross straits, or run offshore, parallel with the coast, between wind generation fields and major cities on the coast.
At the same time, the HVDC cable would provide a coastal bus that links the Southern and East coast states. From Port Lincoln in South Australia, Victoria & Tasmania, New South Wales, to Townsville in Queensland.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
