Newtons 2nd Law of motion Practical Questions
The discussion centers on practical questions related to Newton's 2nd Law of motion, specifically regarding an experiment with a cart and hanging weights. The relationship between acceleration and system mass is identified as inversely proportional, while acceleration is directly proportional to force when mass is constant. Participants clarify that the goal of transferring weights from the cart to the mass hanger is to maintain a constant system mass while varying the accelerating force. This method ensures accurate results in observing the effects of force on acceleration. Understanding these relationships is crucial for correctly interpreting the experiment's outcomes.
gregerson888
So i have a few questions in relation to a practical completed in grade 11 Physics
The basic experiment about the 2nd law, in which a hanging weight is used to accelerate a cart
the practical also had a 2nd part in which weights were added to the small cart to decrease the acceleration while keeping the hanging mass constantso we know F=MA
State the relationship between the acceleration and the system mass as proportionality
if i rearrange F=ma i get a=f/m and m=f/a
could i answer this question with something like...
the acceleration is directly propertional to the force when mass is constant?
or
The mass is directly propertional to force when acc. is constant?
State the relationship between acceleration and acceleration force ( N ) as a proportionilty?
another question i have is
Why is it necassary to transfer the masses from the trolley to the mass hanger rather than simply adding more masses to the mass hanger
im not asking for complete answers, i just seek help so those can guide me in the right direction and what i should be answering with
Each of the relationship questions is asking you to compare two variables - disregard any others that are not mentioned in the question.
For example: State the relationship between the acceleration and the system mass as a proportionality.
The only variables given are mass and acceleration. What is the relationship between the two?
F = MA
A = F/M
A = 1/M x F (this is just so you can visualize the two variables as indiviual from each other)
Therefore, A is inversely proportional to M and is directly proportional to F. However, the question does not ask you to relate A to F. Therefore, the answer is this: The acceleration value is inversely proportional to mass value.
Note: this is true whether or not the force is constant - all it means is that if the mass is increased, the acceleration will decrease and vice versa.
State the relationship between acceleration and force ( N ) as a proportionality.
Stuff you probably don't need to show:
F = MA
A = 1/M x F
Stuff you definitely do need to show:
The acceleration value is directly proportional to the force value.
As for your last question, I am uncertain as to its intention. It asks... Why is it necessary to transfer the masses from the trolley to the mass hanger rather than simply adding more masses to the mass hanger? ...but why is it necessary to do what? I don't understand exactly what the goal of the experiment (though I have an idea) was - perhaps if I knew that it would make it an easier to answer. Could you go into more depth regarding the nature of the experiment?
-elkface
cheers mate
Since you are keeping a constant system weight it is important to keep the same weight throughout the tests. By transferring the weight from the car to the hanging weights you are keeping a constant system mass, whilst changing the accelerating force.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
