Newton's laws of motion -- finding the velocity of a Block in a pulley system
The discussion centers on determining the upward velocity of block B in a pulley system when the cord at point A is pulled down at 2 m/s. Participants explore the relationships between the velocities of the blocks and the pulleys, emphasizing the importance of distance ratios and mechanical advantage. The consensus suggests that if block B moves up by a certain distance, the corresponding movement of the pulley supporting A must be carefully analyzed to derive the correct velocity ratio. Ultimately, the conclusion reached is that the upward velocity of block B is 0.5 m/s, factoring in the mechanics of the system. The conversation highlights the complexity of pulley systems and the need for precise calculations in physics problems.
Vv anand
Determine the speed with which block B rises in figures if the end of cord at A is pulled down with a speed of 2ms^-1
Given Velocity downwards at A=2m/s
Really stuck... Couldn't even start the question solving...I know all policies and therefore i am not demanding the question to be solved but just a hint on how to start will surely help
Create some variable names for the different unknown velocities. See what equations you can write to relate them.
Yes that i hv already done... Will start again.. Thx
Yea i started again but ended with nothing..I can show u my work if u want
This is what i did...i m stuck after this!
I don't know if it is allowed, but I used distances instead of velocities.
Just took a starting position, moved the block B 1 unit distance and calculated the distance each other bit moved if the string stayed tight.
That gave me a velocity ratio.
If mass B moves up ##\delta##, how much does the pulley that supports A move down?
Is it 3##\delta##
Vv anand said:
Is it 3##\delta##
No. Look at the diagram carefully.
Oh is it 4 ##/delta##
Just because of the middle string attached to the mass coming from the upper left pulley
No. Look carefully. The wire between pulley
I get that the pulley supporting A moves down ##\delta## if mass B moves up ##\delta##. This focuses on the wire that passes over pulley D.
Sir I am coming to the solution that since pulley supporting B moves up the pulley supporting a moves down 3##/delta## as i hv to ke
Yes sir...i got that the ##/pulley## is moving delta downwards
Wrote that upper comment by mistake...
So if ##v_B## is the upward velocity of mass B, what is the downward velocity of the pulley that supports A?
Sir vb
Vv anand said:
Sir vb
But this brings me to the solution that vb=2/3.
Yes. So?
But sir the solution is 0.5 m/s
I guess I don't agree.
I confirm 0.5m/s.
When I first looked at this, I got VB=2VA/3, but when OP asked for more info on how, I checked and am now convinced that it is VA/4
When I pull with force T, I find a mechanical advantage of 4:1, by just looking at all the tensions. (assuming massless blocks, light frictionless strings, etc.)
Since you noted the blocks move equally, surely the section from C to E shortens twice as fast as the other two legs?
Perhaps you could expand on your reasoning?
Likes Vv anand
The set-up is sufficiently complicated that it is best to take a very disciplined approach.
There are four distances of interest: AC, CE, CD, DE.
We need four equations to relate them. Some equations will be that one distance is the sum of others, while others will be that a sum of distances is constant.
@Vv anand , what equation relates:
AC, CE, DE?
CD and DE?
AD, AC and CD?
CD, CE and DE?
Like this?
Vv anand said:
Like this?
Yes, that works.
@haruspex I'm trying to get an understanding of where I went wrong. Was I correct in assessing that, if ##v_A## is the downward velocity of A and ##v_B## is the upward velocity of B, then the rate of increase in length of the segment of wire between A and the pulley that supports A is ##v_A-v_B##?
EDIT: Ooops. That's not correct. I really messed up on this one.
Chet
10K
