B Newton's Rings central spot brightness
When light is illuminated from below a plano-convex lens, the central spot appears bright due to constructive interference, while illumination from above results in a dark central spot due to a phase change from reflection. The difference in brightness is attributed to the refractive index of the materials involved, where light refracted through glass experiences a pi phase shift. The presence of reflection at the interface between two identical materials, like glass, affects the intensity of transmission, with no reflection leading to higher transmission intensity. The discussion highlights the interplay of light behavior and material properties in optical phenomena. Understanding these principles is essential for applications in optics and lens design.
versine
How come when the illumination is from below, the central spot is bright, but when the illumination is from above, the central spot is dark?
Do you know what causes the rings?
I think when shining light from underneath, whether a central bright fringe is obtained or not also depends on the thickness/height of the plano-convex lens.
For the light above case, at the centre, the 2 rays travel the same distance, only that one is reflected off a medium (air) of lower refractive index, so no phase change. The other is refracted off a medium of higher refractive index (glass), so there is a pi phase change, leading to a central dark spot
Hi sir, could you please explain why shining light from underneath produces a bright spot at the centre?
Let's say you are on the other side of the glass from the light. The center of the curved and straight glasses touch. Will you get any reflection at the interface (hint: is it really an interface if two identical materials are in direct contact)?
If you get reflection, what effect does this have on the intensity of transmission? If you get no reflection, what effect does this have on the intensity of transmission?
Likes sophiecentaur, vanhees71 and phantomvommand
This is an example of why I love PF so much. Just a few words and no equations to give pretty much the whole story!
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
