Newtons Second Law: Finding net forces
The discussion centers on calculating the force exerted by a spaceship on its pilot during lift-off from the Moon, where gravitational acceleration is 1.6 m/s². The pilot's weight on Earth is 735 N, which translates to a mass of 75 kg. The net force is determined by adding the weight of the pilot and the upward acceleration, leading to a total force of 195 N. Participants clarify that both forces are considered positive because the normal force exceeds the weight when the pilot accelerates upward. The explanation emphasizes the importance of understanding the forces acting on the pilot without considering external factors like the spaceship's engine.
battlebball
A spaceship lifts off vertically from the Moon, where g = 1.6 m/s2. If the ship has an upward acceleration of 1.0 m/s2 as it lifts off, what is the magnitude of the force exerted by the ship on its pilot, who weighs 735 N on Earth?
From Halliday, Fundamentals of Physics, 9e
Newton's Second Law: F(net)= ma
I'm more looking for an explanation on why the answer is 195 N.
Granted I can see that they added the two forces. (75kg*1.0m/s2 + 75kg*1.6m/s2)
What I do not understand is why I need to add the two positive forces. I was trying to draw a few body diagram.
What I was picturing: two force vectors in opposite direction. So the magnitude would result in 45N if this were the case.
Thanks in advance.
How much force did the ship exert on the pilot before the ship took off?
When the ship takes off from the ground, does the ship exert more force on the pilot or less?
Take pilot as a center, now
Force acting vertically downward:
1. weight of the pilot
Force acting vertically upward:
1. Normal force
N - W = m.a
N = W + m.a
= 75(1.6) + 75 (1.0)
= 195 N
Hint: Mass = 75 kg because its 735/9.8
You need to know, why they added two force. Whenever you consider anybody in mechanics, forget everything about its surrounding. Don't think that there is an engine which is also exerting force. When we will consider aircraft as our body then there will be two force W and the force exerted by the engine. And since the aircraft is moving upward it means that the force exerted by the engine is more than the weight of aircraft but here in the problem, pilot is our body and only two forces (normal reaction and weight) are acting on it. Since the pilot is moving upward (in the same direction as that of normal reaction) therefore normal reaction is greater than weight.
snshusat161 said:
N - W = m.a
N = W + m.a
Thanks for the responses everyone. This pretty much explained it for me. I wondered why the weight wasn't calculated with a negative, but it was then added to find the normal. Thanks
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
