B NGC 4590, more than 1,400 stars found in various evolutionary stages
  • B
  • Thread starter Thread starter Astronuc
    Stars
Astronomers using India's AstroSat spacecraft have inspected ultraviolet bright sources in the globular cluster NGC 4590, revealing over 1,400 stars in various evolutionary stages. This cluster, located about 33,900 light years away, is estimated to be 11.2 billion years old and is known for its metal-poor composition. The study highlights the significance of blue horizontal branch stars and other UV-emitting sources in understanding stellar evolution. While Hubble can observe in ultraviolet light, the James Webb Space Telescope (JWST) focuses on infrared, limiting its ability to study such UV sources. The findings contribute to a deeper understanding of star formation and the evolution of early-type galaxies.
Astronuc
Staff Emeritus
Ultraviolet bright sources inspected in NGC 4590​
https://phys.org/news/2022-02-ultraviolet-bright-sources-ngc-stars.html
Using India's AstroSat spacecraft , astronomers have inspected ultraviolet (UV) bright sources in a globular cluster known as NGC 4590, which had previously been viewed with Hubble.
Globular clusters (GCs) are collections of tightly bound stars orbiting galaxies. Astronomers perceive them as natural laboratories enabling studies on the evolution of stars and galaxies. In particular, globular clusters could help researchers to better understand the formation history and evolution of early-type galaxies as the origin of GCs seems to be closely linked to periods of intense star formation.
GCs are great places to resolve and observe the properties of individual stars of various evolutionary stages. Studies show that sources with effective temperature higher than 7,000 K mostly contribute to the ultraviolet (UV) emission of GCs. Such UV bright sources in GCs may be identified, for instance, as blue horizontal branch stars (BHBs), extremely blue horizontal branch stars (EHBs), or post-asymptotic giant branch stars (pAGBs).
At a distance of about 33,900 light years, NGC 4590 (also known as Messier 68) is a very metal-poor galactic GC in the Milky Way's northern hemisphere. The cluster is estimated to be 11.2 billion years old and its line of sight is at a level of 0.05. Previous observations of NGC 4590 have found that it hosts a significant number of BHBs and red horizontal branch stars (RHBs).
https://arxiv.org/abs/2202.03981
Will this area be a target for JWST? Or, probably not based on the following:
https://www.rmg.co.uk/stories/topics/james-webb-space-telescope-vs-hubble-space-telescope
Hubble’s main focus is on visible and ultraviolet light. Its instruments can observe a small portion of the infrared spectrum from 0.8 to 2.5 microns, but not to the extent that James Webb can. Instead it focuses its unique ultraviolet (0.1 to 0.4 micron) capabilities on work that cannot be done from the ground and its visible (0.4 to 0.8 micron) light instruments on producing the high resolution images we are most familiar with
JWST has been designed to focus on the infrared part of the spectrum from 0.6 (red light) to 28 microns (infrared). This means it won’t be able to see in ultraviolet light like Hubble, but will be able to focus on infrared bright objects like extremely distant galaxies
Astronomy news on Phys.org
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
