scott_alexsk
- 336
Hello,
Recently I have been pondering the change in transformation temperature of Nitinol, with various alterations. For example, annealing the wire at prolonged high temperatures,( say 600 C for 30 min.) will result in a decreased transformation temperature between the martsenite and the austenite states. In this case impurities are removed from the crystal, by allowing the atoms (with high temperature) to move around to the most stable state.
However the annealing temperature is also altered in a less understood way. The transformation temperature is decreased by increasing the content of nickel. The only explanation I can think of for this change is that simply since the nickel atoms have a smaller radius than the titanium atoms, the internal friction is decreased by allowing more 'wiggle room'. (I understand that all the electrons in the unfilled shell of all the atoms are 'floating around' but wouldn't the electrons that remain with the nickel atom, be held closer than the titanium's because of the larger positive charge?)
This seems to be backed up by the fact that when platnium is substituted in for Nickel the transformation temperature increases. Since the platnium atoms have a larger diameter than the nickel atoms, then does that not increase internal friction, and the transformation temperature? I know I could be completely wrong on this, but in all the papers I have reviewed, none have commented. (By the way the transformation between martsenite and austenite is a transformation between a face-centered cubic crystal and a body-centered cubic. )
Thanks,
-scott
Thanks,
-scott
