No gravity at center of earth= no pressure?
In summary, the conversation discusses the concept of net gravity and pressure at the center of a sphere, specifically the Earth. While the gravitational force at the center is zero, the layers of Earth above still exert a crushing weight, resulting in pressure. The value of gravity increases as you move away from the center, and each layer of Earth must support the layers above it. The conversation also delves into the role of individual atoms and electrons at the center and the effect of rotation on pressure.
  • #106
Drakkith said:
The gravity isn't zero at the center of the earth.
Why do you think this?
  • #107
There are two 'Gravities'to consider.
1. The Force of gravity.
This is the sum of the attractions of every particle in the Universe on any object - mostly we only need to consider the effect of all the particles of the Earth. When at the centre, these forces will cancel out, because they are uniformly in all directions.
2. The Gravitational Potential
This is to do with the Energy needed to move an object around 'against gravity'. Arbitrarily, the GP at a point is defined as the energy required to bring an object from Infinitely far away so, for an attractive force, it is a negative quantity. The graph of GP against distance has zero at infinity and forms a 'well' (we've all seen the rubber sheet model).
The shape of the graph follows a 1/d law (d = distance from the centre) as you approach the surface but, once below the surface, the graph still continues down but it follows a d2 law with a zero at the centre. This means that (of course) you need to supply energy to get up to the surface and even more to escape. As it happens, it requires the same energy to get from the centre (uniform Planet - the simplest model) to the surface as from the surface to the same distance outwards. (see attachment)
So there is no force at the centre but you still need to Work to get away from the centre. You are at the bottom of a flat bottomed potential well.
I need to put to bed a statement that someone made that "you are attracted to the Centre of Mass". This is an approximation and is only true for all objects when you are far enough away.
e.g. The CM of the Earth/Moon combination is a point below the surface of Earth. If you are standing on the Moon, however, you are attracted towards the Moon (more or less, to the centre of it) - which is NOT the CM of the Earth/Moon.
  • #108
Malibuguy said:
Of the four forces: electromagnetism , strong forces, weak forces and gravity - don't most physicists who have at least a phd believe that gravity is the most poorly understood?
But the level of 'not understanding' is way beyond what is being discussed here. There is no need to leave the Classical realm to discuss this stuff.
  • #109
Why wouldn't I? The gravitational force doesn't simply disappear to my knowledge. You would be in the center of a large gravity well.
  • #110
You're in the center of a large gravitational well, but the gradient of the potential is zero.
  • #111
Ok? That doesn't mean that gravity doesn't exist there.
  • #112
It means the gravitational force is zero.
  • #113
The force is equalized yes, but gravity still affects you.
  • #114
Try to make sense of the graph in that earlier post of mine and appreciate the difference between Force and Potential.
  • #115
I completely understand the two. The force of gravity from everything around you is equal, so you don't experience any net pull in a direction. You obviously are contributing to the mass and gravity of the center of the earth, as gravity is still working and doesn't suddenly just disappear.
  • #116
The question of is there a difference between zero resultant or net force and zero force?
is actually a pretty deep philosophical one.
We are asking the question: If A-B=0 is there a difference beween when A[itex]\neq[/itex]0 & B[itex]\neq[/itex]0 and A=B=0?
I contend that there are certainly circumstances when there is a real difference.
Take for instance the situation of my wallet.
I have a £10 (B=£10) note in my wallet an I go into a restaurent and eat a meal. I then pay £10 for the meal (A=the bill). I now have zero money left
so A-B=0
But I have had a meal and I once had £10, much better than for the beggar outside for whom A=B=0
  • #117
Wouldn't the beggar beg for money and get say €40.
And then, rather than saving it, he would go to an expensive restaurant and eat even better than you did, spending the €40 and making sure he had nothing left, spending left overs on extras, like booze.
So he started with nothing, didn't really do anything for it, and ended with nothing.
A - B = 0 - 0 = 0
But he did have a better meal! :smile:
  • #118
Umm?
I think that, if you did, you would not be viewing this as some sort of a paradox (that is what comes over in your posts). There is none but the rather sloppy use of the word Gravity can lead to confusion.
If you regard Potential as the basic quantity (energy is the way forward for understanding most things) then there is a scalar field of GPE in a region. The force is just the gradient of that field. A gradient can be zero so the force can easily be.
If you lay a spring on a flat surface and fix one end, there is no force on the other end until you try to displace it. The spring is still there - along with its 'springyness' even if it's not pulling or pushing anything.
  • #119
I don't see anything complicated about this. The attraction of gravity doesn't cease to exist simply because you are in the center of something. The mass in your body attracts all the mass around you and vice versa. Just like being in a hollow sphere you don't experience any net force in a direction, but it is still there. There is no philosophical anything here.
Edit: Sophie, I have absolutely no idea what you are trying to say. How can I put it any simpler than "Gravity exists in the center of the earth"?
  • #120
Choosing to use the example of a hollow (empty) shell at the center of the Earth that is supporting all of the weight of the mass outside the shell, there is no compressive force inside the shell (I'm assuming there is a vacuum inside the shell). There is no gravitational force within the shell. The gravitational potential all points inside the shell is the same, so the gradient is zero, but the potential at all points within the shell is a large negative value (not zero), the same as any point on the inner surface of the shell.
  • #121
Of course. But if you put an object inside this shell then it still attracts everything else outside the shell. I don't know which terms to use. Force? Net force? Attraction? Every time I've used something it apparently is taken completely wrong and I don't know why.
  • #122
something I've always wondered was, when they say the E field is zero inside a hollow charged cavity. Sure it cancels mathematically but how does it cancel physically, it seems the fields would have to interact somehow to cancel. I don't know if what i said sounds right. And also time dilation is different in the middle of the Earth then out in deep space where the field is zero. So some how the clock can tell the difference.
  • #123
A - B = 0 - 0 = 0
New month's resolution
Change my profession.
:smile:
  • #124
Time dilation is related to gravitational potential, not gravitational field strength. Again using the hollow shell at the center of the Earth example, then all points within that hollow shell experience the same large negative gravitational potential and time dilation.
http://en.wikipedia.org/wiki/Gravitational_time_dilation
  • #125
I am saying that there is no Force but there is Potential. If there is no gradient of Potential, there is no Force. Just using the word "gravity' is too unspecific to mean anything.
You can only say that 'gravity exists at the centre of the Earth' in the same sense that gravity exists everywhere - because it goes with the existence of all the matter in the Universe. You can't have one without the other. The gravitational energy is just very 'patchy'; in some places it is a lot lower (i.e. more negative) than in others.
  • #126
sophiecentaur said:
center of Earth ... there is no Force ... there is potential.
There is no field either, just a potential. If you put an object inside a hollow shell at the center of the earth, the only field there is due to the object itself. The objects field does interact with the surrounding mass.
  • #127
Isn't potential a man made invention, the fields are what we experience and interact with,
how would my clock sense a potential if there is no field for it to interact with?
  • #128
Natch - Field is Force on a Unit Mass, by definition.
The object in the middle will, as usual, be interacting with the sum total of masses in the Universe.
  • #129
That is a deep philosophical point. Isn't it all a man-made invention? Fields are only a way of interpreting what we see happening to things. The whole thing can be looked at in terms of Energy just as well. You can never say what things 'really' are. You can only use models and the Force model may have its appeal to you because it sort of feels right - nothing more.
Try some QM using forces alone - that could prove tricky.
  • #130
That is exactly what I've been saying. Did you bother to read my other posts explaining what I meant? I thought it was pretty clear exactly what I meant by "Gravity". I have no idea how I could possibly explain it in terms that you would agree with, so sorry.
  • #131
Okay can anyone tell me what is the upper limit of gravity? Obviously if you are in space away from any mass than gravity can be zero. But how large can it get? And what are the conditions?
  • #132
Ever heard of a Black Hole? That's about as high as you can get as far as I know.
  • #133
Hmm but what is the strength of gravity of the black hole?
  • #134
If, when you mean Gravitational Force, you mean that an, when you mean Gravitational Potential , you say that then there can be no confusion. But "gravity" is generic, like "electricity" and is too vague for nitty gritty discussion.
"Gravity" is everywhere in the same way that "time" is.
You mustn't mind my being picky but so many people take such liberties with poor old Science. It's a wonder she let's us know anything about her.
  • #135
The core of most planets is much denser material than the outer layers. Surface gravity doesn't correlate well with the diameter, since the mass of the core is more important. So again standing on mount Everest you weigh less because you are further away from the core. And digging down at least to the surface of the core which is 7/8 to the center may not mean that gravity is decreasing.
  • #136
someone raised the point that gravity might not be the reason why the core of the Earth is made out of dense molten iron.
lets consider the moon. most scientists believe the moon came about from a collision where part of the Earth's crust was knocked off the earth. The moon therefore did come about with a metal core from birth. But that core formed. The moon was very hot due to the energy of the collision This heat would allow iron to be molten and flow. If gravity were zero in the center then wouldn't the iron reside as a shell not on the inside but on the surface according to those who believe that gravity decreases as you move in either direction from the surface until it reaches zero at the center.
  • #137
There was a lot of energy released in the formation of the Earth. As the Earth cleared its orbit of matter the potential energy that the matter had would be changed to heat. I believe it was enough to liquify the Earth. The heat is maintained by the radioactive decay of radioactive isotopes of uranium, thorium, rubidium, potassium and others. There is enough heat released by these to maintain the liquid core. It was calculated by Lord Kelvin from the known heat flux of the Earth that it was roughly 100 million years old. This answer was not pleasing to either fundamentalist Christians or geologists. The discovery of radioactivity resolved that problem, at least for geologists. So the Earth lost almost all of its heat of formation in the first hundred million years or so.
The Moon on the other hand is much smaller than the Earth an has a much higher surface area to mass ration and it long since cooled all the way through.
And the surface of the outer core is roughly half way to the center. But since volume has a cubed relation to the radius that means that the outer core/mantle boundary is roughly at half of the way to the center, not 7/8. And until you do hit that boundary the force of gravity slowly goes up. At the outer core/mantle boundary the acceleration due to gravity would be about 10.8 m/s^2.
And lastly, no, just because gravity is zero at the center does not mean that dense materials would avoid the core for any reason. . The heaviest materials are still attracted to the center more than lighter material would be.
  • #138
That's only true for the idealized case of a uniform sphere of mass. Obviously, if the material has a denser layer below the surface, you may well increase the gravitational force on a test mass that is brought below the surface. (The case of moving the test mass above the surface is too trivial to discuss.) Of course, as you get to the center the gravitational field strength will go to zero for any spherically symmetric mass distribution, even one with denser layers. (Let's leave out special cases like black holes. :wink:)
  • #139
Why would the iron move to the center of the moon.
The moons rotation and orbit would exert forces greater than the zero gravity center so that one would expect a metal shell not a solid center
  • #140
Could you put some figures to that assumption? We're not talking fairground rides here. What difference would you expect in the effective gravitational forces on different parts of the Moon due to the Earth c/w its local distributed masses?
