No Laplace Transform? What can be said about the function?
A function that lacks a Laplace transform does not necessarily imply a specific characteristic about its behavior or properties, unlike the clear connection between the absence of a Fourier transform and infinite energy. The Laplace transform is primarily a tool used in engineering to transition between time and frequency domains. While convolution in the time domain corresponds to multiplication in the frequency domain, the absence of a Laplace transform does not directly indicate a fundamental issue with the function itself. The discussion highlights confusion regarding the relationship between Laplace transforms and other mathematical concepts, such as Fourier series and Dirichlet conditions. Ultimately, there is no clear theoretical implication for functions without a Laplace transform.
hadron23
Hi,
We know that if a function does not have a Fourier transform, then it does not have finite energy. Is there an equivalent intuition associated with a function that does not have a Laplace transform?
hadron23 said:
Hi,
Could you provide a link to your first assertion please?
Alright, I think I got confused with something to do with Fourier Series (not transform) and Dirichlet conditions. Nevermind that first statement. The question is, what can be said about the function, if it does not have a Laplace transform?
Laplace Transform is just a means engineers convert representations in time domain into frequency domains in engineering. Things in time domain do happen in frequency domain. as F= 1/T. Convolution (which is complicated) in the time domain means multiplication in the frequency domain - which helps things out.
Not too sure there is any existence between if a function has no laplace means other theory.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
