No redshift in a freely falling frame
In summary, the redshift of light in a freely falling frame is not observed due to the Equivalence Principle, which states that the effects of gravity are indistinguishable from the effects of acceleration. This means that in a small freely falling frame, where tidal effects are negligible, an observer will not perceive any gravitational redshift. However, this only applies if both the source and observer are freely falling and close to each other. Mathematically, this can be shown using the Fermi normal metric, which accurately describes the effects of gravity to second order.
  • #36
Austin0 said:
How could it not start out at At t=0, [itex]v_{1}[/itex] = [itex]v_{2}[/itex] = 0 ? it does not instantaneously attain its final proper acceleration ,yes?? It would seem it would have to start out at 1 and over some finite time interval reach the relative ratio.
You missed the point that he got the wrong answer. So, his attempt at applying the second set of equations failed. The two approaches need to produce the SAME answer, otherwise he's found a way to disprove EPE. The measured ratio is [itex]X_1/X_2=\sqrt{\frac{1-v/c}{1+v/c}}[/itex], not 1 and, definitely NOT [itex]\sqrt{\frac{1-(v_1/c)^2}{1-(v_2/c)^2}}[/itex]. THAT was the point.
It would appear that if stevendaryl's calculation of relative rate as the relationship between instantaneous gammas is incorrect then a basic principle of SR falls. Specifically the Clock Hypothesis. Delta t' for either clock must be equal to an integration over that worldline interval based on instantaeous (infinitesimal) velocity gammas ,yes?
Clock hypothesis has very little , if any, to do with this problem.
  • #37
It looks to me like these two quantities refer to two different things. The first refers to Schwarzschild spacetime; the second refers to Rindler coordinates on Minkowski spacetime. The answers for those two cases will not be the same, because Schwarzschild spacetime is curved and Minkowski spacetime is flat.
  • #38
GAsahi said:
This part of the derivation is in error. If you did it correctly, you would have gotten that the correct result is [itex]\frac{d \tau_1}{d \tau_2}=\sqrt{\frac{1-v/c}{1+v/c}}[/itex] where [itex]v[/itex] is the instantaneous speed of the rocket containing the two clocks wrt the launcher frame.
That was exactly my point: You can't compute redshift by just computing d[itex]\tau[/itex]1 in terms of dx and dt, computing d[itex]\tau[/itex]2 in terms of dx and dt, and dividing them.
  • #39
That's exactly the point: your method of computing redshift gives the wrong answer unless two conditions are met:
(1) You are using a coordinate system in which the metric components are independent of time, and
(2) You are using a coordinate system in which the sender and the receiver of the light signals are both at rest in that coordinate system.
If those two conditions don't hold, then you can't simply compute d[itex]\tau[/itex]1 and d[itex]\tau[/itex]2 in terms of dx and dt, and get the right answer for redshift.[/QUOTE]
  • #40
No, both are about flat spacetime. The difference is that
√(1-(v1/c)2)/√(1-(v2/c)2) is the ratio of the two clock rates, as measured in the "launch" frame, while √(1-v/c)/√(1+v/c) is the redshift formula for the case in which the "lower" clock sends a signal while at rest, and the signal is received by the "upper" clock when that clock is traveling at speed v. (Since the light signal takes time to propagate, the upper clock will have achieved a nonzero velocity while the light signal is in flight).
My point is that the redshift formula is NOT the same as the ratio of clock rates, except in very specific circumstances. Those circumstances actually hold for Rindler coordinates and for Schwarzschild coordinates, but they don't hold for arbitrary coordinates. The conditions for being able to equate "relative clock rates" with "redshift" are: (1) The metric tensor is independent of time, and (2) the sender and receiver are at rest in the coordinate system.
  • #41
Correct.
Incorrect. A simple disproof can be found in the way N.Ashby does the computations explaining the GPS functionality (see his paper in Living Reviews). The receiver and the emitter are NOT at rest wrt each other.
  • #42
This is standard textbook stuff, I have given you a couple of links that contradict your statement.
  • #43
It has nothing to do with the equivalence principle--the same two approaches can be used in Schwarzschild geometry or in flat spacetime, and you get the same two answers. Those answers are NOT the same, because they are asking different questions:
  1. What is the ratio Rlower/Rupper of the rate of the upper clock to the rate of the lower clock? This ratio is a coordinate-dependent quantity. It has different values in different coordinate systems. That's true for flat spacetime and for the Schwarzschild geometry.
  2. What is the ratio fupper/flower of a light signal sent from the lower clock to the upper clock, where fupper is the frequency of the signal when it is received, as measured by the upper observer, and flower is the frequency of the signal when it is sent, as measured by the lower observer. This ratio has the same value in every coordinate system, and is less than 1 (the frequency as received is lower than the frequency as sent). That's true for flat spacetime and for the Schwarzschild geometry.
The two ratios are only the same for a special coordinate system in which (1) the components of the metric tensor are time-independent, and (2) the two clocks are at rest in that coordinate system.
  • #44
Actually, IF you do the calculations correctly and IF you apply the EPE correctly, they ARE the same, with a very high degree of precision. EPE tells you that they must be the same. Attached please see the complete calculations.
  • EquivalencePrinciple38.doc
  • #45
You are very confused. What I pointed out is that there are two different ratios that can be computed: (1) the ratios of clock rates, and (2) the ratios of frequencies for a light signal sent from one observer to another. Those two ratios are only the same in the special case in which the coordinates used are such that the components of the metric tensor are time-independent, and the two observers are at rest in that coordinate system.
What in the textbook contradicts the above statements?
Note, that the two conditions are true for Schwarzschild coordinates (which are the coordinates usually used in Pound-Rebka experiments). They are also true for Rindler coordinates. But they are not true for arbitrary coordinates.
  • #46
Yes.
No. I have already corrected you on this statement. IF it were true (it isn't) the GPS calculations would not work. Please see the N.Ashby paper in Living Reviews as reference.
  • #47
No, they are not the same, to a high degree of precision. They are different ratios: One is a ratio of clock rates, as measured in the "launch" frame. The other is the ratio of frequencies for a light signal. Those two ratios are NOT the same.
  • #48
I appended my calculations that show they are the same (with a very high degree of precision).
Can you post your calculations that support your PoV?
  • #49
What your enclosed calculations show is that the ratio of clock rates (which is computed in the first calculation using Schwarzschild coordinates) gives the same answer as the redshift formula (computed in the second calculation using Doppler shift). I'm AGREEING with that. The redshift formula is a coordinate-independent quantity, which has the same value in any coordinate system (if it's done correctly). The ratio of clock rates is a coordinate-dependent quantity; it has DIFFERENT values in different coordinate systems. But--and I've already said this several times--if you use special coordinates in which (1) the metric is independent of time, and (2) the sender and receiver are at rest in that coordinate system, then for that particular coordinate system, the two answers are the same.
Your calculations are not contradicting those claims, they are illustrating them. If instead of using the Schwarzschild coordinates to compute relative clock rates, you had used a different coordinate system to compute relative clock rates, you would have gotten a different answer. I showed you that, by using inertial coordinates to compute relative clock rates for accelerating clocks. The ratios of the clock rates are 1 at time t=0, as computed in the inertial coordinates of the "launch" frame. That MUST be the case, because the clocks are initially at REST, and in inertial coordinates, the only relevant factors involved in clock rates are velocities. But the redshift formula does NOT a null result. If gives the same result whether you use inertial coordinates or Rindler coordinates.
  • #50
You are very confused. GPS calculations don't contradict what I have said. What I said is that redshift formula does not agree with the ratio of clock rates in an arbitrary coordinate system. That is certainly true. I gave you an explicit calculation proving it.
GPS calculations are done in a very specific coordinate system; most likely Schwarzschild coordinates, since that's the most convenient for an approximately spherically symmetrical case. In Schwarzschild coordinates, it IS the case that the redshift formula between two observers at rest (say, one at the bottom of a mountain, and one at the top of a mountain) will be equal to the ratio of clock rates.
(Of course, the real situation for GPS calculations is a lot more complicated, because Earth-based coordinates are a rotating coordinate system, relative to the Schwarzschild coordinates, and because sender and receiver may not be at rest, so we have to include Doppler effects as well as the Schwarzschild effects.)
What I've said is indisputably true. The ratio of clock rates is a coordinate-dependent quantity. Redshift between two observers is a coordinate-independent quantity. Those two statements are indisputably true.
  • #51
Then what are you splitting hairs about?
Your second condition is false , as shown by the way the GPS calculations are being done. I have already pointed this to you three times. The emitter and the receiver are in motion wrt each other, yet the calculations hold.
It is not clear what mistake you made but I get the SAME result through both methods. If your claims were true the GPS calculations would fail.
  • #52
When they are NOT at rest wrt each other, the redshift formula is NOT the same as the ratio of the clock rates. The redshift differs from this rate by a Doppler correction. They explicitly say that in the Wikipedia article about Pound-Rebka:
Special Relativity predicts a Doppler redshift of :
[itex] f_r=\sqrt{\frac{1-v/c}{1+v/c}}f_e[/itex]
On the other hand, General Relativity predicts a gravitational blueshift of:
[itex]f_r=\sqrt{\frac{1-\dfrac{2GM}{(R+h)c^2}}{1-\dfrac{2GM}{Rc^2}}}f_e[/itex]
The detector at the bottom sees a superposition of the two effects.
  • #53
The emitter and receiver are NOT at rest wrt each other. The calculations done using Schwarzschild coordinates are confirmed by practice. So, your second claim is false.
  • #54
You misread the wiki paper: it tells you that the way to measure the gravitational effect is by cancelling it with the appropriate amount of Doppler effect by moving the source wrt the detector at the appropriate speed.
  • #55
Because you are making a serious mistake in confusing two different things:
(1) The ratio of clock rates, and (2) the redshift formula. They are not the same, except in special circumstances.
No, they don't. If the emitter and receiver are in motion, then the redshift formula has to be adjusted to include both position-dependent and velocity-dependent effects.
I didn't make a mistake, you did.
... but I get the SAME result through both methods. If your claims were true the GPS calculations would fail.
You didn't compute d[itex]\tau[/itex] in terms of dt and dr for any coordinate system other than Schwarzschild. My claim is that if you had used a different coordinate system to compute d[itex]\tau[/itex] for the two clocks, and taken the ratio, you would have gotten a different answer than you get for Schwarzschild.
For you to say "if your claims were true the GPS calculations would fail" makes no sense, because what I'm saying AGREES with what you are saying when Schwarzschild coordinates are used to compute d[itex]\tau[/itex]. Since you haven't attempted to compute d[itex]\tau[/itex] for any other coordinate system, the point of disagreement hasn't come up.
Well, it actually has come up, in the Rindler case, but you wisely declined to offer a calculation of d[itex]\tau[/itex] in that case.
  • #56
Why do you think that that says something different from what I'm saying? I'm saying that if the two detectors are in motion relative to one another, Doppler shift must be included in the redshift calculation. That's clearly true. They say it right there in the article.
It explicitly says: "The detector at the bottom sees a superposition of the two effects",
where the two effects are position-dependent time dilation, and Doppler shift.
  • #57
If the detector and the emitter are not at rest relative to each other (as measured in Schwarzschild coordinates) then the pure position-dependent gravitational time dilation must be corrected by an additional Doppler term. Are you disputing that? That's very bizarre. Think about it: suppose that the receiver and the sender are at the SAME height. Then the redshift is purely due to Doppler.
You CAN'T use the gravitational time dilation to compute redshift without including Doppler, except in the special case in which the sender and receiver are at rest (so that the Doppler effect is zero). You're not seriously disputing that, are you?
  • #58
Repeating the same error ad nauseaum doesn't make it right. Your so-called "counter-example" has the source and the emitter at rest wrt each other.
You are desperately trying to prove that the method does not apply when the emitter and the detector are moving wrt each other (you changed the goal posts when I showed you that the method works when there is no relative motion). The GPS calculations , as posted by Ashby, disprove your statement.
So, you have a "counter-example" that does not apply and your statements are contradicted by mainstream application of Schwarzschild coordinates to explaining the GPS functionality. You are 0 for 2.
  • #59
Hm, ok, I need to go back and read your original posts more carefully. However, I'm not sure GAsahi is talking about flat spacetime (but maybe I need to go back and read his original posts more carefully too).
This is not correct as you state it; the circumstances are not coordinate-dependent. See below.
It would be better if you stated these conditions in coordinate-free terms, which can be done:
(1) The spacetime has a timelike Killing vector field;
(2) The sender and receiver's worldlines are both orbits of the timelike Killing vector field.
That should make it clear that the conditions you are talking about depend on particular properties of the spacetime and the worldlines, but *not* on coordinates; the mathematical description of the conditions looks simpler in Schwarzschild coordinates (or Rindler in flat spacetime), but that doesn't mean it's only "true in" those coordinates.
  • #60
I showed you how to do the calculations using the Schwarzschild solution for the case of relative motion between source and detector. You do not need any "additional Doppler term", the answer is fully contained in the Schwarzschild solution. You seem to have this bee under your bonnet that you can only use the Schwarzschild solution when the source and the detector are stationary.
  • #61
Whether two objects are at rest wrt each other is a COORDINATE-DEPENDENT fact. In Rindler coordinates, two clocks at different values of the X coordinate are at rest relative to one another. In inertial coordinates, they are not at rest relative to one another.
It clearly doesn't. You know that's the case. If the receiver and the sender are at the SAME height, and are moving relative to one another, then there will be a nonzero redshift. The redshift formula in that case is not the same as the position-dependent gravitational time dilation formula. I can't believe you're disputing that.
No, they DON'T. They are in complete agreement. What is true is that the Schwarzschild relative clock rate calculation gives the same answer as the redshift calculation in the case where the sender and receiver are stationary in the Schwarzschild coordinates. If they are NOT stationary in the Schwarzschild coordinates, then there is an additional Doppler effect that must be taken into account. Are you seriously disputing this?
  • #62
Good, you finally got this right despite multiple previous protestations.
You are either missing the point or you are trying desperately to move the goalposts. If the source and the receiver are moving wrt each other, the effect is WHOLLY described by using the Schwarzschild solution, Doppler AND gravitational effect all rolled in ONE formula, the one formula derived SOLELY using the Schwarzschild solution. You can find that solution posted in this forum. You seem to be disputing that the solution is valid though it is the standard approach to solving such problems (see the references to Neil Ashby).
  • #63
You didn't do the case in which the sender and receiver are at the SAME radius r, and have a relative velocity v in the direction perpendicular to the radius. Your method gives the WRONG answer for this case, if you don't include the Doppler effect.
  • #64
GAsahi, I can't find a link in this thread to the Ashby paper you are referencing. Do you mean this one?
http://relativity.livingreviews.org/Articles/lrr-2003-1/
  • #65
No, they're NOT. You are deeply confused about this point. Consider the case in which the sender and the receiver are at the SAME radius r. For example, they are both on the surface of the Earth, on the equator. But they are in relative motion. They are traveling in opposite directions, one traveling east and the other traveling west. One observer sends a signal to the other. Let f1 be the frequency of the signal as measured by the sender, and let f2 be the frequency as measured by the receiver.
In this case, the two frequencies will NOT be the same. They will differ by a Doppler shift. How are you proposing to compute that Doppler shift solely using the Schwarzschild metric?
The answer is: you can't. f1/f2 is NOT equal to d[itex]\tau[/itex]1/d[itex]\tau[/itex]2 in that case.
  • #66
He's not, but flat spacetime is a special case of curved spacetime. If the technique works in general, then it should work in flat spacetime, as well.
The claim that I'm making, which is really an indisputable claim, it's pure mathematics, is that the ratio of two clock rates for distant clocks is a coordinate-dependent quantity. This is easily seen to be true in SR: In the twin paradox, during the outward journey, each twin's clock is running slow, as measured in the coordinate system in which the other twin is at rest. The ratio of two clock rates is a coordinate-dependent quantity. It's true in SR, and it doesn't become less true in GR.
My point is that there are two different ratios to compute:
(1) The ratio f1/f2 of a light signal sent from one observer to another, where f1 is the frequency as measured by the sender, and f2 is the frequency as measured by the receiver.
This quantity is completely independent of coordinates, and you can calculate it using whatever coordinates you like.
(2) The ratio R1/R2 of clock rates for the clocks of the two observers.
This quantity is coordinate-dependent. If you use different coordinates, you get a different ratio.
Specifically, R1 = d[itex]\tau[/itex]/dt = √(gαβ dxα/dt dxβ/dt. This rate has different values in different coordinate systems.
What's special about Schwarzschild coordinates (or Rindler coordinates) is that ratio (2) is equal to ratio (1) for those coordinates, but not for other coordinates.
You are right, that if there is a Killing vector field, then we can come up with a corresponding ratio by defining R1 = d[itex]\tau[/itex]/dt, where dt is the timelike Killing vector, instead of a coordinate. In that case, R1 is no longer coordinate-dependent.
  • #67
yes,of course.
  • #68
For one definition of "ratio of two clock rates", yes this is true. But there are other possible definitions.
Yes, but when the twins come together, the traveling twin has experienced less elapsed proper time, which of course is *not* a coordinate-dependent statement. So if I define "ratio of two clock rates" in terms of elapsed proper time between some pair of events common to both worldlines, then the ratio is not coordinate-dependent.
Of course, if the two worldlines don't cross, there won't be a pair of events common to both worldlines. But there may still be a coordinate-independent way to pick out "common" events on both worldlines. For example, if the spacetime has a timelike Killing vector field which is hypersurface orthogonal (as Schwarzschild spacetime does), I can pick two spacelike hypersurfaces orthogonal to the Killing vector field and say that the "common" events on each worldline are the events where the worldlines intersect the two surfaces. This, of course, is a roundabout way of saying "pick the events on each worldline with Schwarzschild coordinate times t1 and t2", but you'll note that I've stated it in a coordinate-independent way. I could do the same thing for a pair of Rindler observers with non-intersecting worldlines.
In a sense all these choices of "common events" are arbitrary; but they do match up with particular symmetries of the spacetime, so they're not completely arbitrary. They do have some coordinate-independent physical meaning.
Yes, agreed.
This depends, as above, on how you define "relative clock rates". You note this as well, since you agree that we could use a timelike Killing vector field as the "dt" in R1.
Didn't you point out that there are some pairs of observers (such as two observers on Earth's equator but at opposite points) for whom ratio (1) different from ratio (2) even in Schwarzschild coordinates? Perhaps what you meant to say is that ratio (1) is equal to ratio (2) for observers who are *static* in these coordinates?
It may also be worth noting that Schwarzschild coordinates and Rindler coordinates both have a Killing vector field as "dt", so the two definitions of R1 amount to the same thing in those coordinates.
  • #69
Easy, as already explained for the case of radial motion:
[tex]\frac{d \tau_1^2}{d \tau_2^2}=\frac{1-r_s/r_1}{1-r_s/r}\frac{1}{1-\frac{v^2}{(1-r_s/r)^2}}[/tex]
The first factor represents the "gravitational redshift" component, the second factor (speed dependent) represents the "Doppler" component.
I can easily do that for the case of circular motion but I will leave that as an exercise for you. Hint: you use the fact that [itex]dr=0[/itex] and you use the full Schwarzschild metric (you do not drop the rotational term in [itex]d \theta[/itex].
I frankly do not understand how you got this bee under your bonnet.
  • #70
I should elaborate on what I mean by that:
What I thought was being proposed was that a way to compute
f1/f2
is the following:
The Schwarzschild metric:
d[itex]\tau[/itex]2 = (1-r/rs) dt2 - 1/(1 -r/rs) dr2 - r22
So let one observer be at "rest" at r=R. Then we have for that observer:
d[itex]\tau[/itex]1 = √(1-R/rs) dt
Let the other observer be also at r=R, moving at speed v along the θ direction; that is R dθ/dt = v. Then we have:
d[itex]\tau[/itex]2 = √(1-R/rs - v2) dt
Now, my claim is that d[itex]\tau[/itex]1/d[itex]\tau[/itex]2 will NOT give the correct redshift for signals sent from the first observer to the second observer.
