NodeMCU Design With ESP32 Instead of ESP8266
  • Thread starter Thread starter Keonte45
    Design
The discussion centers on developing a NodeMCU module using the ESP32 instead of the ESP8266, with a specific requirement for the layout to match the NodeMCU V3 module. A participant suggests purchasing a pre-made NodeMCU ESP32 board instead of attempting to create a new module, citing the need for advanced skills for PCB design. Concerns are raised about the potential for intellectual property issues in replicating existing designs. Ultimately, the original poster considers sourcing the module from suppliers rather than pursuing the DIY approach. This highlights the challenges of custom PCB design in the context of existing hardware solutions.
Keonte45
Hi,
In the current project I'm working on, I want to develop a NodeMCU module using ESP32 rather than ESP826. The most recent module in this series is AS ESP32. In order to use it, the layout must be the same as the NodeMCU V3 module's.
So, if possible, could someone help me out with the project's PCB design?
Thanks.
Keonte45 said:
Hi,
Thanks.
It is not clear what you are trying to do.
If you want to run NodeMCU on an ESP32 then search for "NodeMCU ESP32" on Amazon/AliBaba/your local development board supplier and buy one. If you need a specific pinout then make an adapter board.
If you really do want to "develop a NodeMCU module" I am afraid you are going to need more skills and knowledge than you can get from asking about PCB designs here, and we are not going to help you copy someone else's IP anyway.
My plan was to develop a NodeMCU module with ESP32. I guess I'll just try to get it from a supplier instead of making it. Thanks!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
