Engineering Noise Floor/Device Temperature Problem
The discussion revolves around calculating the noise temperature of a Low Noise Amplifier (LNA) using the noise power equation. The user converted -100 dBm to dBW and attempted to derive the overall system noise temperature, ultimately arriving at a calculated LNA temperature of 262.3 K. Concerns were raised about this temperature being high, with suggestions that the antenna's noise temperature, rather than its physical temperature, should be considered. Participants agree that the method appears sound but have not verified the calculations. The conversation emphasizes the importance of understanding antenna noise temperature in relation to device performance.
ashah99
Please see an attachment below.
Pn= 10*log10(kTB)
dBm = dBW - 30 [dB]
Hi everyone, I would like to get some help with the following problem. I'm not sure if my answer is feasible. Thanks.
My attempt at a solution:
I used the noise power equation: Pn= 10*log10(kTB) and converted the -100 dBm to dBW by subtracting 30 dB to get -130 dBW. Then I tried to find the overall system noise temperaure, T, and then I subtract the antenna temperature to find the temp of the LNA.
Pn= 10*log10(kTB) = Pn= 10*log10(k) + Pn= 10*log10(T) + Pn= 10*log10(B)
-130 dBW= 10*log10(1.38e-23 J/K) + 10*log10(T) + Pn= 10*log10(20e6 Hz)
10*log10(T) = -130 dBW - (-228.6 dB/J/K) - 73 dB/Hz = 25.6 dB/K
T = 10^(25.6/10) = 362.3 K
T_LNA = T - T_antenna = 262.3 K
This seems quite high for LNA device temperature. Could someone help to see if my work is right or if I'm totally off-track or misinterpreting the problem?
Why should the temperature of the dish introduce noise? It is a metal sheet with negligible resistance.
Actually 100K is very cold so I think they mean Antenna Noise Temperature, not physical temperature. I think your method is OK but have not checked the numbers.
My assumption was antenna noise temp as well. Would you kind as to check if I’m on the right path?
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
12K
