Noise Modelling - Digital communication systems
The discussion revolves around a teacher seeking clarification on a noise figure calculation in a digital mobile communication system. The problem involves a receiver with a noise bandwidth of 200 kHz and an input SNR requirement of 10 dB at an input signal of -104 dBm. The teacher is puzzled by the inclusion of a -30 value in their calculations, suspecting it may relate to a conversion between dBW and dBm. Participants suggest that the -30 could indeed represent such a conversion factor. The conversation highlights the importance of understanding unit conversions in signal processing calculations.
CMW328i
Hi all, Teacher here looking for some guidance. I'm teaching a class that I took myself a few years back, and I'm looking at my solution to a problem but I have a random value in my answer (which I know to be correct) but I can't for the life of me remember where this value came from! Can anyone help?
1. Homework Statement
A receiver in a digital mobile communication system has a noise bandwidth of 200 kHz and requires that its input SNR should be at least 10 dB when the input signal is -104 dBm.
What is the maximum permitted value of the receiver noise figure?2. Homework Equations
FdB = Ps -SNR -10log (kTB)
3. The Attempt at a Solution
FdB = (-104 -30)-10 -10log (1.399x10^-23*290*200000) = 6.9 dBI can't for the life of me figure out where the -30 comes from. I even have an excerpt from the book the question came out of and it just shows the -30 in the equation without explaining where it comes from. Any ideas?
I see the input at -104, I see the bandwith, the required SNR, but no origin for -30
Is it a conversion between dB W and dB mW?
Ah ha! That may be it actually!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
