Non-commutativity of unit polar bases
  • I
  • Thread starter chartery
  • Tags
    Chain rule
In summary, "Non-commutativity of unit polar bases" discusses the properties of unit polar bases in the context of non-commutative algebra. The paper explores how these bases exhibit non-commutative behavior when operations are performed, leading to unique implications for mathematical structures and applications in fields such as quantum mechanics and computer science. It highlights the significance of understanding this non-commutativity for further developments in algebraic frameworks and their practical uses.
chartery
40
I'm having trouble(s) showing that unit polar bases do not commute.
Adapting <https://math.stackexchange.com/questions/3288981>
taking: ##\hat{\theta} = \frac{1}{r}\frac{\partial }{\partial \theta} ( =\frac{1}{r}\overrightarrow{e}_{\theta})##
then ##\hat{r}\hat{\theta} = \frac{\partial }{\partial r}\left( \frac{1}{r} \frac{\partial f}{\partial \theta}\right)## by chain rule will differ from ##\hat{\theta}\hat{r} = \frac{1}{r}\frac{\partial }{\partial \theta}\left( \frac{\partial f}{\partial r}\right)##
so far so good, but...in <https://physics.stackexchange.com/questions/198280> (first answer)
(via ##\frac{\partial ^{2}x}{\partial \hat{r}\partial \hat{\theta}} vs \frac{\partial ^{2}x}{\partial \hat{\theta}\partial \hat{r}}##)
##\overrightarrow{e_{\hat{r}}}=\overrightarrow{e_{r}}## seems to justify ##(\frac{\partial }{\partial \hat{r}}\left( -sin\theta \right)= )##, ##\frac{\partial }{\partial \hat{r}}\left( -\frac{y}{r} \right)=\frac{\partial }{\partial r}\left( -\frac{y}{r} \right)##
but I don't see how to apply ##\frac{\partial }{\partial \hat{\theta}}## in ##\frac{\partial }{\partial \hat{\theta}}\left( cos\theta \right)##Finally, when just multiplying out the commutator of Cartesian versions, everything seems to cancel:
##[\hat{r},\hat{\theta}] = \left( cos\theta\overrightarrow{x}+sin\theta\overrightarrow{y} \right)\left( -sin\theta\overrightarrow{x}+cos\theta\overrightarrow{y} \right)-\left( -sin\theta\overrightarrow{x}+cos\theta\overrightarrow{y} \right)\left( cos\theta\overrightarrow{x}+sin\theta\overrightarrow{y} \right)## =0??Evidently, my grasp of the underlying logic of the various manipulations is flimsy. As Jim Hacker said, can you tell me what I don't know :-)?
There are various shortcuts you can use. I'll show some of them via an explicit worked example:
$$[\hat e_\theta \,, \hat e_\phi] ~\equiv~ \Big[ \frac1r \, \partial_\theta ~,~ \frac{1}{r \sin\theta} \, \partial_\phi \Big] ~=~ \frac{1}{r^2} \Big[ \partial_\theta ~,~ \frac{1}{ \sin\theta} \, \partial_\phi \Big] ~.$$In the above, I've moved all the ##r## terms out the front of the commutator because ##r## is independent of ##\theta## and ##\phi##, hence ##r## can pass straight through ##\partial_\theta## and ##\partial_\phi##. (To further check my righthand side above, expand the commutator using the Leibniz product rule ##[A,BC] = B[A,C] + [A,B]C##.)
The next step is $$\frac{1}{r^2} \Big[ \partial_\theta ~,~ \frac{1}{ \sin\theta} \, \partial_\phi \Big] ~=~ \frac{1}{r^2} \Big[ \partial_\theta ~,~ \frac{1}{ \sin\theta} \Big] \, \partial_\phi ~,$$where I've moved ##\partial_\phi## outside of the commutator because ##\theta## and ##\phi## are independent variables. That leaves $$\frac{1}{r^2} \Big[ \partial_\theta ~,~ \frac{1}{ \sin\theta} \Big] \partial_\phi ~=~ \frac{1}{r^2} \;\left[ \partial_\theta \left( \frac{1}{ \sin\theta} \right) \right] \partial_\phi~=~ -\,\frac{\cot\theta}{r^2 \sin\theta}\; \partial_\phi ~=~ -\,\frac{\cot\theta}{r}\; \hat e_\phi ~.$$
If you're having trouble with commutators involving ##\partial## apparently acting on nothing, write the commutator like ##[A,B]f##, where ##f## is an arbitrary function, and expand the commutator explicitly as ##A(B(f)) - B(A(f))##.
HTH.
Likes vanhees71, chartery, PeroK and 1 other person
Shouldn't it be ##1 / r## outside the commutator?
The next step is $$\frac{1}{r^2} \Big[ \partial_\theta ~,~ \frac{1}{ \sin\theta} \, \partial_\phi \Big] ~=~ \frac{1}{r^2} \Big[ \partial_\theta ~,~ \frac{1}{ \sin\theta} \Big] \, \partial_\phi ~,$$where I've moved ##\partial_\phi## outside of the commutator because ##\theta## and ##\phi## are independent variables. That leaves $$\frac{1}{r^2} \Big[ \partial_\theta ~,~ \frac{1}{ \sin\theta} \Big] \partial_\phi ~=~ \frac{1}{r^2} \; \partial_\theta \left( \frac{1}{ \sin\theta} \right) ~=~ -\,\frac{\cot\theta}{r^2 \sin\theta}\; \partial_\phi ~=~ -\,\frac{\cot\theta}{r}\; \hat e_\phi ~.$$
HTH.
More generally, you can see directly that:
$$[\partial_{\theta}, f(\theta)\partial_{\phi}] = f'(\theta) \partial_{\phi} + f(\theta)\partial_{\theta}\partial_{\phi} - f(\theta)\partial_{\phi}\partial_{\theta} = f'(\theta) \partial_{\phi}$$
Likes chartery
Thanks, that does help fix the chain rule version in my head. But I am uneasy starting on tetrads when the other two (via ##\frac{\partial }{\partial \hat{\theta}}##, or especially the Cartesians) imply I am missing some basic understanding of the manipulations of even the simplest 2D unit polars.
If you mean this:
That makes little sense. The commutator applies to operators, not to vectors.
PeroK said:
If you mean this:That makes little sense. The commutator applies to operators, not to vectors.
Yes, I got a bit mixed up between the various e's, thetas, hats, and arrows. It should have been
##[\hat{r},\hat{\theta}] = \left( cos\theta\partial_{x}+sin\theta\partial_{y} \right)\left( -sin\theta\partial_{x}+cos\theta\partial_{y} \right)-\left( -sin\theta\partial_{x}+cos\theta\partial_{y} \right)\left( cos\theta\partial_{x}+sin\theta\partial_{y} \right)##
but the result still seems zero, given commutativity of ##\partial_{x}\partial_{y}## ?
##\theta## is a function of ##x## and ##y##. For example:
$$\cos \theta = \frac{x}{\sqrt{x^2 + y^2}}$$
Likes chartery
Many thanks again. I hope you were not startled by the sound of distant forehead slapping.
HTH.
@strangerep, sorry, I missed you were separate, so forgot to thank you. Now I am working through your reply, I have a question. In the first equality just quoted, what happened to the ##~ \left( \frac{1}{ \sin\theta} \right)\partial_\theta~## term from the commutator? (Assuming the missing ##\partial_\phi## on right is a typo?)
You should work through this yourself. At this level, you need to move away from needing every line in a proof to be fully explained. You need to be able, if necessary, to fill in the blanks yourself.
This seems to be quite a common problem when students move up to advanced undergraduate or graduate level. They are used to being spoon-fed every detail. At a certain level it becomes impossible to give every algebraic step, because there are too many. You need to develop self-sufficiency in this respect.
There's a further clue in my post #2, which you "liked". Hopefully you also understood it!
##\partial_\theta## acting on nothing can be "shortcut" to zero. This is actually a frequently-used trick. To understand it the first time, make the commutator act on an arbitrary function ##g##, like this: $$[\partial_\theta \,, f(\theta)] g~=~ \partial_\theta fg ~-~ f \partial_\theta g ~=~ (\partial_\theta f) g + f \partial_\theta g ~-~ f \partial_\theta g ~=~ (\partial_\theta f) g ~,$$ where we have used the Leibniz product rule.
Therefore, we can shortcut this to say $$[\partial_\theta \,, f(\theta)] = \partial_\theta f ~.$$
Yes, that was a typo. Now corrected.
Likes chartery
I don't think so, unless I'm missing something. Where precisely?
Thanks very much for the spoon-feeding. My knowledge is patchy, and being 'woolly' on the flurry of notations, it helps me avoid overlooking subtleties and errors applying generalisations, which of course are obvious in hindsight. (Sorry @PeroK, was deficiency in grounding rather than inclination.). Otherwise I can find later that I didn't understand as well as I thought.
Never mind, I saw what I was missing. You factored ##1 / r^2## out of the commutator because there are two factors of ##1 / r## inside it.
Likes vanhees71
FAQ: Non-commutativity of unit polar bases
What is non-commutativity in the context of unit polar bases?
Non-commutativity refers to the property of certain mathematical operations where the order in which the operations are performed affects the outcome. In the context of unit polar bases, it means that the product of two basis vectors does not necessarily equal the product when the order is reversed.
Why is non-commutativity important in quantum mechanics?
Non-commutativity is crucial in quantum mechanics because it underpins the uncertainty principle and the behavior of quantum operators. For example, the position and momentum operators do not commute, which leads to the fundamental limits on the precision with which these quantities can be simultaneously measured.
How does non-commutativity affect calculations in vector spaces?
Non-commutativity affects calculations in vector spaces by introducing additional complexity in operations involving basis vectors. When dealing with non-commutative bases, one must carefully consider the order of operations, as reversing the order can lead to different results. This is particularly important in fields like quantum mechanics and certain areas of algebra.
Can you provide an example of a non-commutative unit polar basis?
An example of a non-commutative unit polar basis can be found in the Pauli matrices used in quantum mechanics. These matrices serve as basis vectors in a two-dimensional complex vector space and do not commute with each other. For instance, the Pauli matrices σ_x, σ_y, and σ_z satisfy the relation [σ_i, σ_j] = 2iε_ijkσ_k, where [ , ] denotes the commutator and ε_ijk is the Levi-Civita symbol.
What are the implications of non-commutativity for physical systems?
The implications of non-commutativity for physical systems are profound. It affects the behavior and interactions of particles at the quantum level, leading to phenomena such as entanglement and superposition. Non-commutativity also influences the algebraic structure of physical theories, requiring the use of more sophisticated mathematical tools to describe and predict the behavior of physical systems accurately.
