Non-Constant Acceleration Problem
The problem involves calculating the distance traveled by a Tesla with a non-constant acceleration defined as a(t) = 1 m/s^4 * t^2 over a 10-second interval. To solve this, the velocity function is derived by integrating the acceleration function, resulting in v(t) = t^3/3. Further integration of the velocity function gives the position function, leading to x(t) = t^4/12. When evaluated at t = 10 seconds, the car travels a distance of 833.3 meters. The calculations and approach are confirmed to be correct.
Jewelz
A new Tesla is designed that can perform a non-constant acceleration for 10 seconds of motion. The magnitude of the acceleration is given as a(t) = 1 m/s4t2
Starting from rest, how far does the car travel over this 10 second interval?
This is what is making the question difficult for me. I am unsure what equations to use with a non-constant acceleration.
I tried solving it manipulating the constant velocity and acceleration equations, but everything I have tried has been wrong. Even if someone could point me in the right directions equations wise, I'm sure that would help me a lot.
Thanks
Hi, you can find the velocity function respect to ##t## that is ##v(t)=\int_{0}^{t} a(s)ds## and after the space ##x(t)=\int_{0}^{t}v(s)ds##, put ##t=10 s## in ##x(t)## ...
Ssnow
Thanks
Your input is hard to read; I assume you mean ##a = k t^2,## where ##k = 1 m/s^4.##
Anyway, you get velocity ##v## by integrating ##a## with respect to ##t##, and then you get position by integrating ##v##. No amount of manipulation of the constant-acceleration formulas can do what you need.
Your assumption is correct.
After integrating the acceleration function with respect to time, with the bounds of the integral from ##0## to ##t##, I obtained the function ##t^3/3## for the velocity. Integrating that, from 0 to t for the integral, I got ##t^4/12##, and plugging in ##t## (10 seconds), I obtained a final answer of 833.3m traveled.
Does this all sound correct?
It does.
Yes, perfect.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
