Non-Stick Pots & Pans: Pros & Cons
  • Thread starter Thread starter wolram
Non-stick pots and pans, particularly those with PTFE (Teflon) coatings, can release toxic by-products at high temperatures and may flake over time, raising health concerns. Alternatives like seasoned cast iron and anodized aluminum are favored for their durability and non-stick properties without harmful coatings. Newer non-stick options, such as the Evo Child's Green Pans, are praised for their performance and safety, allowing high-heat cooking without toxic fumes. Users emphasize the importance of proper care, including avoiding metal utensils and using oil to maintain the non-stick surface. Overall, while non-stick cookware can be convenient, it requires careful handling and maintenance to ensure safety and longevity.
Use seasoned cast iron. It's not an issue then.
I don't understand people that think a splash of oil when cooking something makes food dreadfully unhealthy.
Apparently, it is not about the oil but the PTFE (Teflon) coating which tends to break-up at high temperatures releasing potentially toxic by-products. The safest cookwares are the ones made of glass or ceramic.
I know that. My point was that cast iron pans have no coating and when seasoned are basically non stick anyway.
They are far easier to cook with too.
The downside of cast iron is regulary emphasized here.
Weight. Heavy.
The older pans that hve the non-stick flaking off might not be good to use. The newer ones don't flake, also Evo Child was given a set of green pans, and OMG, I love them. The slipperiest pans and they contain no PTFE/PFOA. I read mixed reviews about them, so I was very skeptical, but they're the best pans I've ever used.
Weight. Heavy.
Yet another bonus. You get a nice workout everytime you cook.
Try to explain that to some people.
I have been trying to talk my 89 year old mom to dump the flaky pans, so i think cast iron ones are out, they would be to heavy for her.
In that case some sort of anodised aluminium would be good.
Light, with a hard surface. Not as non stick as PTFE coated pans.
Only lasts a few years before becoming rubbish.
The non stick pans are such a scam they don't last as long as you'll eventually end up eating flakes of the stuff in your dinner... And they are harder to clean! Because you can't scrub as ruff on them plus some things just don't non stick. It's a joke really they take a perfectly good pan and spray it with crud that makes you have to toss it before you even get 1/2 the use out of it you normally would. If your having problems with your pan not getting clean just try cleaning it sooner cause if you don't wait days to clean pans they are generally very easy to clean imo.
That's what I need. I bought one of those non-PTFE pan and it lasted less than a year before it started flaking off whatever it uses.
Weight. Heavy.
But, you need to explicitly state the real hazzard. It's potentially "heavy weight" wielded by "angry wife".
Nonstick pans are great, but they do have their limitations. When using a nonstick pan you should never use very high heat, it will cause the nonstick surface to degrade. If you need a good sear (high heat) try using either cast iron or stainless steel. Never never never use metal utensils in a nonstick pan (i.e. using a fork to scrape the food out). Use a non-metal spatula instead.
Also, don't buy the cheapo $5 pans from walmart. No matter how hard you try, they will start flaking months after use. Cough up the extra money for a quality brand and the nonstick will last for a long time.
My mom all ways threatened us with the rolling pin. :!)
Also much harder to clean.
To be blunt, you're doing wrong then. A well seasoned pan is cleaned with just water, if cleaned when warm it just requires a wipe/mild scrub and it's done.
I'm going to stop now, becuase I am stating to sound like a gay cast iron fanboy.
They're extremely toxic for birds : (
Weight. Heavy.
Workout. Good.
Ugga...
As for cleaning, I simply hit my my cast iron pans with warm watter and a plastic scrubbee. A quick rinse in hot water, dried with a towel, and it's better than ever.
There are some things I'll never cook in my cast iron pan, though, as they tend to stick like there's no tomorrow, eggs being chief among them.
My wife and I have a set of Calphalon One Non-Stick, which is hard-anodized aluminum with some "special polymer" in there. They work well, and have a lifetime warrantee. Pretty much nothing can stick to the coating, which I love.
I flip omelettes in my cast iron pans, and I'm not very muscular; in fact, I have especially weak wrists. The weight is not an issue, but you have to be aware of body mechanics. I don't use my wrist to flip omelettes; I hold my wrist straight, and use my upper arm and shoulder. And with the big 10-lb dutch oven, just got to remember to lift with your legs, not with your back, etc.
Eggs never stick for me. Just use a little butter, and they slide around like they're on ice. What sticks like crazy is rice. I don't think I'll do that again.
You must not be burning your food often enough.
Dupont admits that the teflon pans will kill pet birds. I wonder if it affects a developing fetus.
Ben Niehoff said:
I flip omelettes in my cast iron pans,...
I've always wonder how they (TV food cooks) flip things in skillets to mix the ingredients. Every time I try, I loose most of it.
I think I know the ones you're talking about...they got good reviews on Amazon. But of course I take the opinion of one PFer far more seriously than dozens of commoner's opinions, so thanks :approve:!
I have Calphalon and like it a lot, but I've been using the Evo Child's Green Pans and they blow away any pan I've ever used, and I hate anything "Green". I was ready to hate these pans. I *wanted* to hate these pans. I love them.
You can actually brown and sear in these pans the same as in stainless steel, but the food just slips out.
http://www.green-pan.com/
I'll definitely check those out :cool:!
(I'm totally with you on the "green" thing...marketing, sigh :rolleyes:)
OK. The verdict is in: the "Green Pan" is awesome! I bought one several weeks ago, and tonight bought another one (a wok :!)).
Thanks for the tip, Evo!
Even with nonstick pans, a small amount of oil should be applied prior to cooking with them.
I use cast iron for most of my cooking, and have gotten quite a collection, most for free as people who don't want them or know how to care of them simply get rid of them.
Quite a few of mine are virtually nonstick with the usage they've gotten.
Plus side, never suffer from iron deficiency anemia.
We have the same set and are pretty impressed. They work very well.
  • · Replies 18 ·
  • Poll Poll
  • · Replies 36 ·
