Non uniform charge distribution on conductor surface
A non-uniform charge distribution can indeed exist on a conductor's surface due to external influences, such as a nearby point charge. The presence of an external charge alters the electric potential in the surrounding space, prompting the charges on the conductor to rearrange themselves. This rearrangement ensures that the conductor's surface remains equipotential despite the external influence. Any external charge distribution will similarly lead to a non-uniform charge distribution on the conductor's surface. Understanding this concept is crucial for analyzing electrostatic conditions in conductors.
vinaysaxena93
Hey everyone! I need some help.
Can a non uniform charge distribution exist on a conductor's surface due to some external influence? Please explain bearing in mind that a conductor's surface is equipotential.
Sure, for example if you have a point particle located somewhere off the conductor's surface. The presence of the point particle changes the potential everywhere in space, and so the charge on the conductor's surface has to rearrange itself to keep the surface at the same potential.
In fact, generally speaking, any sort of external charge distribution will cause a nonuniform charge distribution on the conductor's surface, for basically the same reason.
Thanks diazona, I got the concept. :smile:
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
